Control Hatch Pattern Line Weights
Message 1 of 81
I found this being posted by number of people and a lot of answers marked as solutions. But they don't seem to work.
Hatch patterns seem to be understood as taking a default pen width 1. So While playing around for changing these hatch weights, I changed all pen 1 widths to 0.5mm, for all scales, in Manage > Settings > Additional Settings > Line Weights > Model Line Weights - Perspective Line Weights > Annotation Line Weights.
Nothing seems to change hatch pattern or cut surface pattern line weights. Could any sage help?
Accepted solutions (4)
Replies (80)
Message 2 of 81
kadmonkee
in this example i duplicated a Filled Regions Pattern and changed the Line Weight basded on its assigned number 1,2,3,4
now the original Pattern Diagonal Crossed  Hatch (default will remain as Pen 1)
Diagonal Crossed  Hatch 2
Diagonal Crossed  Hatch 3
Diagonal Crossed  Hatch 4
simply duplicate your chosen Pattern rename it and change the line weight, is this not working for you?
are you using Model Hatch or Drafting Hatch?
there should be no need to change the lineweight settings in your model to change the result for Filled Regions,
unless I am missing something?
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
Message 3 of 81
amorap
Hello from Spain
For me is working well, as expectted.
Check if you have activated thin lines.
regards.
Augusto Mora
Architect & teacher of Building Projects at CPIFP Pirámide. Huesca (Spain).
Revit 2014 certified profesional.
Message 4 of 81
I'm kinda new at this but I have noticed that some materials us pen 1 and others use pen 2.  I do not know how you would assign a pen to a material.
Just a small clue.
Matthew
Message 5 of 81
kadmonkee
materials are IMAGE based
Drafting fill patterns are based on the scale of the view.
Model fill patterns are based on the actual dimensions in the building model.
all filled regions can be assigned a line weight , color, tranparency or Opaque in thier properties
thank you
Message 6 of 81
@kadmonkee, It certainly works in Fill Patterns, when gone in Annotate > Detail > Region.
WallSection_LW.JPGWhat I am looking for is object hatch patterns. For e.g. Wall Cut patterns, as shown in the attached image.
Message 7 of 81
amorap
Hi from Spain:
The only way that I guess to override this is modifying  the linework and pattern in VG or modifying the Object Style, but in both cases I havent seen any option to set the lineweight for patterns.
regards.
Augusto Mora
Message 8 of 81
kadmonkee
if you select the wall / edit type / Structure (edit button)
on the Materials column find the material you want to modify.
select the material button to bring you into the Material Browser
when you select the cut pattern it is reading the Drafting fill pattern - duplicate and rename this and change the properties to a hevier line weight and apply it here.
any modifications you do here will effect all of your Model using this particular Material.
maybe duplicate and customize for testing
thank you
Message 9 of 81
Sahay_R
@Anonymous you are correct. The only way to control the color / lineweight of a fill pattern would be to create it accordingly. Annoying, but true.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 10 of 81
@kadmonkee, Could you please help with more detail? I seem to be missing something.WallSection_LW_2.JPG
Message 11 of 81
Try changing line weight 2.  Through the material the only way to change the line weight is to change the color or the grey scale.  Materials all have the same line weight.
To achieve the appearance of varying line weights for similar patterns:
I think what is being suggested is to re-create the pattern.  Copy the pattern to a new file.  Add lines to the pattern that are so close together that they print as 1 line.
Matthew
Message 12 of 81
kadmonkee
the Fill Pattern you are using to make the BRICKWORK is a Fill Pattern
change the line weight of THAT Fill Pattern.
I have assigned the Fill Pattern of "Diagonal Crosshatch (Drafting) as my BRICKWORK Fill Type.
edit the Fill Pattern that is Part of the Material.
thank you
Message 13 of 81
RobDraw
There are no hatches in Revit.
Rob
Message 14 of 81
I beg to differ.
Fill Pattern is not Filled Region.
What you show is how you change the line weight of the Fill Pattern of a Filled Region type.  You can have different Filled Region types using the same Fill Pattern but with different line weights.  That has nothing to do with the Material Pattern line weights.
Message 15 of 81
Sahay_R
@kadmonkee What you have pointed out works beautifully for filled regions (above), but not in walls (below).
Rina Sahay
Message 16 of 81
kadmonkee
so I cant add a fill pattern with a specific lineweight to a material cut Pattern and have appear correctly?
thank you
Message 17 of 81
No you can't.
Again, Fill Pattern do not have any specific line weight.  Only Filled Region types do.
Message 18 of 81
kadmonkee
thank you for clearing that up.
it seemed too simple.
I feel embarrassed for leading the OP down the wrong path
thank you
Message 19 of 81
No worry.  These terms are quite confused and can be easily misunderstood.  Same as line styles/ line patterns/ line weights.
Message 20 of 81
Thank you @ToanDN. That cleared up any remaining doubts. I will mark your post as solved, to get the attention of fellow users to the correct answer.
