Error While Loading pyRevit – IronPython TypeLoadException in Revit 2023
drashti_barot
Message 1 of 1
drashti_barot
I encountered an error while reinstalling and loading pyrevit. Please find the details below:
Error Title:
pyrevitloader – Ironpython TypeloadException: Could not load type System.Resources.NeutralResourcesLanguageAttribute
Error Details:
  • Source: pyRevit (IronPython engine)
  • File Traceback:
    C:\Users\<User>\AppData\Roaming\pyRevit-Master\bin\engines\pyRevitLoader.py C:\Users\<User>\AppData\Roaming\pyRevit-Master\pyrevitlib\pyrevit\__init__.py C:\Users\<User>\AppData\Roaming\pyRevit-Master\pyrevitlib\pyrevit\framework.py
  • Error Message:
    SystemError: Could not load type 'System.Resources.NeutralResourcesLanguageAttribute' from assembly 'System.Runtime, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a'.
  • Script Executor Traceback (Key Part):
    System.TypeLoadException: Could not load type 'System.Resources.NeutralResourcesLanguageAttribute' from assembly 'System.Runtime, Version=4.0.0.0, Culture=neutral'.
Possible Cause:
IronPython failed to resolve a .NET Framework class (NeutralResourcesLanguageAttribute) from the System.Runtime.dll assembly.
This typically occurs when the .NET Framework 4.7/4.8 runtime is missing or corrupted, or due to a mismatch between pyRevit’s IronPython engine and the installed .NET libraries.
Request:
Could you please review this issue and advise on the recommended steps (repairing .NET Framework / switching to CPython engine / clean reinstall of pyRevit)?
Replies (0)
