Can't make type curtain panel
3 REPLIES 3
3363 Views, 3 Replies
I have made custom curtain panels real life like with specific width. I created curtain wall with this panels and when the length of curtain wall is not a multiplied by curtain panel length then the error messege can't create type and replace panel with empty pane shows up. Do you have any suggestions how to overcome this issue and to keep my curtian panels with any length of curtain wall?  Should I change the last empty panel for any  different kind of  joint  or connector panel to replace empty panel ?
I have attached a file rvt 2017
3 REPLIES 3
constantin.stroescu
Usually the CW Panels have no fixed dimensions , and when loaded into a CW frame they stretch to fill the space of the cells created by Curtain Grids.
As long as you have to use standard Panels with fixed dimension (as fabricators make them), then you have to accept either to have walls with length multiple of your Panel width, or create another custom Panel to fill the remaining space.
Constantin Stroescu
constantin.stroescu
You have to think like a constructor does on site......
Constantin Stroescu
in reply to: constantin.stroescu
Thanks, that confirmed what i was thinking.
Forma Design Contest
