Sheet organize
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
glkirk
481 Aufrufe, 4 Antworten
Sheet organize
Good morning,
I hope this finds all well!
I want to make my "Drawn by" a label, so that it will show in "Manage Project information and I can use it as a label instead of typing it into every sheet.
I know I have a lot more to learn about this, but if I could understand this, It might give me a start.
Thank you!
4 ANTWORTEN 4
Nachricht 2 von 5
glkirk
als Antwort auf: glkirk
Forgot to send this screenshot
Nachricht 3 von 5
constantin.stroescu
How I accomplish something like this:
  1. in Title Block Family create a Shared Parameter : create first ( if you not already have) a custom Shared Parameter File, then a Group and finally the Parameter ,let's sau DRAWN BY
  2. Make a Label that contains this Parameter and place it into the Title Block drawing . Load TB into the Project
  3. in Project : Manage >Settings > Project Parameters > Add >Parameter Properties>Shared Parameters> Select - select the Shared Parameter created in step 1. Categories Project Information
  4. Appear in Project Information panel , and you can type a text that will be unchanged
1.
2.
3.
4.
Constantin Stroescu
Nachricht 4 von 5
Yien_Chao
that should work with a shared parameter.
Nachricht 5 von 5
bill_gilliss
What you seem to be looking for is a project parameter that will be applied automatically to all the sheets. See
Add Custom Fields to a Titleblock:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2018/EN...
You will probably want to create your own shared parameters file as part of that process.
