How to buy
Privacy | Do not sell or share my personal information | Cookie preferences | Report noncompliance | Terms of use | Legal | © 2025 Autodesk Inc. All rights reserved
Hi everyone!
Im currently imporitng an AutoCAD file to Revit 2014, and by doing this I have also imported the 100+ lines that my team have created on the detail. These NEW revit files have so much data that are making all of the file HUGE!
Is there a way to make my detail only have a few line, and or if they ARE already set as Revit files...Can I have all of their lines just set as one or even four? Instead of having 100+ lines.
Thanks a lot!
In AutoCAD create new layer say "z" select all lines change the layers of all lines to "z", then import/link in Revit.
sanchalf
First thing i would do is recommend you LINK CAD rather than IMPORT CAD, importing a CAD file is always going to bloat your Revit file, Linking a CAd file will not add much file size at all to your Revit file.
And it would just be a matter of cleaning up your CAD file inside AutoCAD or w/e 2D package you use. Open the CAD file up, delete the unwanted stuff (text, tables, etc.) and do as Suresh mentioned and place everything on the 1 layer. Re-save the CAD file with a new name (so you don't override the original) and then LINK it into your Revit project file.
Hope this helps
How to buy
Type a product name
