I'm trying to write a tool to create an AssemblyInstance, but I cannot find a way as of yet, so I'm reaching out. We start by grabbing a couple elements within a drawing. I use the Selection to get the ElementID's and then Element's themselves, and place them in a List<Element>.
I've looked through Document.Create and there is no AssemblyInstance - I also checked through Document.Create.NewFamilyInstance, but that requires a Symbol among other things; which AssemblyInstance's aren't even FamilyInstances to begin with if I'm not mistaken.
I've also looked in to simply overriding a keyboard shortcut, but Create Assembly doesn't seem to have one.
Any help on where to look for this would be a huge help.
Thanks in advance!
Found my solution: You have to have a `NamingCateogryID` that can be grabbed from within any `AssemblyInstance` in the drawing like so:
private ElementId getSpoolNamingCategory() { ElementId pID = ElementId.InvalidElementId; var lSpools = new FilteredElementCollector(m_pDoc).OfClass(typeof(AssemblyInstance)).OfType<AssemblyInstance>().ToList(); foreach (var pSpool in lSpools) { if (pSpool.NamingCategoryId != ElementId.InvalidElementId) { pID = pSpool.NamingCategoryId; break; } } return pID; }
Then you just create the `AssmblyInstance` via the class' `Create` function:
private bool createSpool() { AssemblyInstance pSpool = null; var lIDs = m_pSelected.GetElementIds().ToList(); using (Transaction pTrans = new Transaction(m_pDoc, "Create Spool")) { pTrans.Start(); ElementId pNamingCategoryId = getSpoolNamingCategory(); pSpool = AssemblyInstance.Create(m_pDoc, lIDs as ICollection<ElementId>, pNamingCategoryId); pTrans.Commit(); } return pSpool == null; }
Hi, using Category.GetCategory(document, BuiltinCategory) to the NamingCategory field works for me.
