Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Create New AssemblyInstance
2 REPLIES 2
656 Views, 2 Replies
I'm trying to write a tool to create an AssemblyInstance, but I cannot find a way as of yet, so I'm reaching out.  We start by grabbing a couple elements within a drawing.  I use the Selection to get the ElementID's and then Element's themselves, and place them in a List<Element>.
I've looked through Document.Create and there is no AssemblyInstance - I also checked through Document.Create.NewFamilyInstance, but that requires a Symbol among other things; which AssemblyInstance's aren't even FamilyInstances to begin with if I'm not mistaken.
I've also looked in to simply overriding a keyboard shortcut, but Create Assembly doesn't seem to have one.
Any help on where to look for this would be a huge help.
Thanks in advance!
2 REPLIES 2
Found my solution:  You have to have a `NamingCateogryID` that can be grabbed from within any `AssemblyInstance` in the drawing like so:
private ElementId getSpoolNamingCategory()
    ElementId pID = ElementId.InvalidElementId;
    var lSpools = new FilteredElementCollector(m_pDoc).OfClass(typeof(AssemblyInstance)).OfType<AssemblyInstance>().ToList();
    foreach (var pSpool in lSpools)
        if (pSpool.NamingCategoryId != ElementId.InvalidElementId)
            pID = pSpool.NamingCategoryId;
            break;
    return pID;
Then you just create the `AssmblyInstance` via the class' `Create` function:
private bool createSpool()
    AssemblyInstance pSpool = null;
    var lIDs = m_pSelected.GetElementIds().ToList();
    using (Transaction pTrans = new Transaction(m_pDoc, "Create Spool"))
        pTrans.Start();
        ElementId pNamingCategoryId = getSpoolNamingCategory();
        pSpool = AssemblyInstance.Create(m_pDoc, lIDs as ICollection<ElementId>, pNamingCategoryId);
        pTrans.Commit();
    return pSpool == null;
zefreestijl
Hi, using Category.GetCategory(document, BuiltinCategory) to the NamingCategory field works for me.
Forma Design Contest
Rail Community
