Parameter group creation
kirthigag
Message 1 of 9
kirthigag
Am trying to maintain separate parameter group for the custom created parameter,  can able to create a new group in shared parameter window as well as can able to map any shared parameter in the newly created group. Is there any option to import/use the created shared parameter group inside project parameter "Group parameter under" drop down?
Thanks in Advance😊
Replies (8)
Message 2 of 9
studio-a-int
to Group Parameter Under you need to use:
public override BuiltInParameterGroup ParameterGroup { get; }
ExternalDefinition.ParameterGroup Property
then look at the Enums., and chose the Group you want your Parameter under:
BuiltInParameterGroup Enumeration
Message 3 of 9
RPTHOMAS108
Is this an API question I'm not sure?
In relation to the API those groups are different things:
You have DefinitionGroup items which group parameters in the DefinitionFile (DefinitionFile.Groups)
Then you have BuiltInParameterGroup enumeration which groups the parameters in the UI.
This follows UI functionality where also you can't create them.
Message 4 of 9
kirthigag
Thanks for the response,
The BuiltInParameterGroup enum only have the default items that listed in the project parameter UI, newly created group is not listed in the collection. Is there any method to include the new group in existing BuiltInParameterGroup collection.
Message 5 of 9
kirthigag
Is there any API method available to combine DefinitionFile.Groups with BuiltInParameterGroup, because whenever we add a shared parameter into a project parameter it can only be assigned to the group that listed in project parameter UI, can we customize BuiltInParameterGroup  items?
Message 6 of 9
RPTHOMAS108
No the BuiltInParameterGroup is a fixed list, can't be added to.
Generally if you can't do it in the UI you will not be able to do it with the API.
Message 7 of 9
daniel_duma
It can be done, but Honestly I'm not sure how. Here is an Example:
Message 8 of 9
BDENGF96VQ
Is there any update on this, can this be altered in the API? Or is it perhaps possible to change one group name to another?
Message 9 of 9
Omar-S
dear , Releases / member Forces is already defined in Revit
as far as i know, there are no way to add a new Group parameter in Revit.
