@Anonymous
Welcome to the Autodesk User's Community..
This is a user based forum. We don't issue other users activation codes. They come directly from Autodesk when you properly obtained this product 11 years ago. So may I ask where you got this copy from?
Mark Lancaster
& Autodesk Services MarketPlace Provider
@Anonymous
Not sure why you are posting mutiple times https://forums.autodesk.com/t5/installation-licensing/code/td-p/7819386 about the same thing. IF this is related to the AutoCAD 2007 version.. The only way you are going to get an activating code is that you properly purchase this 11 years ago. This product is retired and no longer supported by Autodesk. Where did you get this legacy version from?
Mark Lancaster
@Anonymous
This is a user forum which means users don't send other users activation codes. They come directly from Autodesk when you properly obtain this product 11 years ago. Where did you get this legacy version from?
Mark Lancaster
Mark Lancaster
Hello @Anonymous,
Welcome to the Autodesk Community !
As mentioned in previous post, to obtain an Activation Code, you will need to contact our Registration & Activation team. Please go to Contact Us - Activation & Registration, then click on "Request an activation code".
>> Somebody help me pls to activate autocad 2007 with request
>> number H7FOK438QK3DSR53NAY3NAY9ZLWD urgently
As it's urgent: The fastest help you can get is to read the posts above ... because then:
- alfred -
Just because you found a copy of the product while cleaning out your desk, doesn't mean you can use or activate it. Its an asset that belongs to the company you use to work for. If you want it and to activate it.. The company has to file a transfer of license ownership to you. Meaning someone from that original company has to fill out paper and assign it. In the end its not worth to do this for a 19 year old product.
Mark Lancaster
Auth Now'); // -->
@Anonymous
This is a user forum... Users don't sent other users activation codes. Where did you get this 12 yr old/retired/no longer supported product?
Mark Lancaster
@Anonymous wrote:
Kxu7 qcpn ty3s l0p3 axyk 5u1k
And what does this even mean? If you're trying to activate a legacy version of AutoCAD did you even bother to read any the replies that are already here? Again this a user forum and we don't provide Autodesk activation.
Mark Lancaster
>> Plz sand me too
Have you read the posts above? There you'll find how to get your code for your bought license.
No need to wait for an answer here.
- alfred -
