Previous Version Support
Welcome to Autodesk’s Previous Version Support Forums. Share your knowledge, ask questions, and explore Previous Version Support topics.
activation code for autocad 2007
110 REPLIES 110
Message 1 of 111
289042 Views, 110 Replies
Tags (2)
110 REPLIES 110
Message 101 of 111
pendean
in reply to: lawsonets
>>>...I need activation codes for Land Desktop 2007 and getting the run around...<<<
@lawsonets Autodesk is no longer authorizing 2010 and older software today.
>>>... My Land Desktop showed it never expired but it is useless if you can't get activation codes...<<<
Autodesk is no longer authorizing 2010 and older software today: hire a lawyer, sue them, in 1-2-5-10-20 years you might just win. Rr not.
BUT... you can open a ticket with the Licensing support and confirm your options for sure here https://knowledge.autodesk.com/contact-support/installation-activation
Message 102 of 111
ahmad_naz72
I need activation code for autocad 2007
Message 103 of 111
RobDraw
in reply to: ahmad_naz72
You should read the thread. Your answer is in there.
Rob
Message 104 of 111
abdulrehmanstt
HJQY LF90 RZ88 T0P3 W70W HC16 this is my request code.
Please send me activation code.
Message 105 of 111
RobDraw
in reply to: abdulrehmanstt
Good luck!
Rob
Message 106 of 111
mostofakamal
Sir i need serial number and activation code
And the product will be resistered individual
Message 107 of 111
lawsonets
in reply to: mostofakamal
The computer generates a request for an activation code and then AotoCad
would supply the activation code - and AutoCad Civil design would run -
So you asking for the activation code has me confused - are you asking for
the data I sent to Acad ????
Message 108 of 111
mbrwktfrhat
I need activation code for autocar 2007 serial number xxx-xxxxxxxx sequest code: ZEK3 C2L4 URG1 PFP3 QU27 PFA8
Message 109 of 111
pendean
in reply to: mbrwktfrhat
No one here is able to do that for you: read the posts above yours for about your only options.
Message 110 of 111
sroy8940
serial number  :-  xxx-xxxxxxxx
Request code   :-  VFET SP5C FPQF K7P3 9JWH 7403
please send me activation code
Message 111 of 111
pendean
in reply to: sroy8940
https://forums.autodesk.com/t5/previous-version-support/activation-code-for-autocad-2007/m-p/1238174...
Administrator Productivity
