>>>...I need activation codes for Land Desktop 2007 and getting the run around...<<<
@lawsonets Autodesk is no longer authorizing 2010 and older software today.
>>>... My Land Desktop showed it never expired but it is useless if you can't get activation codes...<<<
Autodesk is no longer authorizing 2010 and older software today: hire a lawyer, sue them, in 1-2-5-10-20 years you might just win. Rr not.
BUT... you can open a ticket with the Licensing support and confirm your options for sure here https://knowledge.autodesk.com/contact-support/installation-activation
You should read the thread. Your answer is in there.
HJQY LF90 RZ88 T0P3 W70W HC16 this is my request code.
Please send me activation code.
Good luck!
Sir i need serial number and activation code
And the product will be resistered individual
@mbrwktfrhat wrote:
I need activation code for autocar 2007 serial number xxx-xxxxxxxx sequest code: ZEK3 C2L4 URG1 PFP3 QU27 PFA8
No one here is able to do that for you: read the posts above yours for about your only options.
