i've double check that the xgen plugin is loaded , but once i order the "create intreractive groom splines' nothing appears on the poly surface , please help , what should i do ?
Solved by mspeer. Go to Solution.
All the best,
Sean Heasley
Technical Support Specialist
Autodesk Here to Help | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Installation and Licensing Forum | Maya Certified Hardware |
Hi!
"it doesn't work"
What does this mean?
You can't activate it, or
you can activate it, but XGen will still not be shown?
Also check in Outliner if the XGen description will be created.
