Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
xgen interactive doesn't generate hairs , how to solve ?
10 REPLIES 10
Message 1 of 11
1095 Views, 10 Replies
i've double check that the xgen plugin is loaded , but once i order the "create intreractive groom splines' nothing appears on the poly surface , please help , what should i do ?
10 REPLIES 10
Message 2 of 11
sean.heasley
Hi! Did you have the geometry selected when you went to create the xgen hair? Also, did any warnings or errors pop up when you tried this? Let me know if anything changes!
Message 3 of 11
in reply to: sean.heasley
of course i select the geometry "poly" & then i choose from generate "create interactive groom splines" , also i tried to keep the script editor open while i repeat the try with a new file but nothing pop ups over there , neither error message nor any message at all in the script editor
Message 4 of 11
mspeer
Hi! You need Viewport 2.0, Legacy Viewports can't display XGen Interactive.
Message 5 of 11
in reply to: mspeer
& how to get it ?
Message 6 of 11
mspeer
Hi!
Viewport menu: Renderer -> Viewport 2.0
Message 7 of 11
in reply to: mspeer
Hi , i tried it , it doesn't work
Message 8 of 11
mspeer
Hi!
"it doesn't work"
What does this mean?
You can't activate it, or
you can activate it, but XGen will still not be shown?
Also check in Outliner if the XGen description will be created.
Message 9 of 11
in reply to: mspeer
once i check on the viewport 2 under the renderer in viewport , the viewport2 doesn't apply .
Message 10 of 11
mspeer
Hi! Then there is a problem with your GPU / driver. - Make sure you use a proper 3D graphic card for Maya. - Update graphic card driver (maybe just re-install after an OS update), or - downgrade graphic card driver. - Try different Viewport modes (in Preferences).
Message 11 of 11
in reply to: mspeer
thank you a lot
