Unfold3D process error
staceypeck
Message 1 of 76
staceypeck
I'm trying to unfold my UV map and I keep getting an error that says "// Error: Unfold3D process error." How can I resolve this?
Replies (75)
Message 61 of 76
imstudent1712
same error keep coming me i do also have ryzen 3
Message 62 of 76
interactm
from a previous reply:
there is a solution... you need to edit maya.env and add this line.
"MAYA_USE_ALTERNATE_UNFOLD_SHIM = 1"
Message 63 of 76
Do you have any other solutions to this at all?
KayT
Message 64 of 76
pathadedhiraj1
Observer
Observer
It worked for me too. BTW i am using ryzen 3700X
Message 65 of 76
bali.shotgrid
For people with the same problem. I find out the error comes from the uv shell with about 90 degree shape in the 3d mesh, try to cut more in the corner, even if this smooth rounded, when the degree is more than 90 overall will make the error, unfold shell by shell until all faces is unwraped, and sew the uv's  using Stitch Together tool until we archiving the desired result, hope it's help
Message 66 of 76
GABolz
Observer
Observer
@Anonymous Thank you! This worked for me. Not sure why, but thanks for posting your solution!
Message 67 of 76
gretaricciolini
Observer
Observer
Hi, I'm new to Maya, I'm using Maya LT for an assignment and I have this error everytime I use unfold, optimize or even layout. I'm not able to texture the asset properly and importing it in unity.
I tried your solution, but it doesn't help as Unfold3D is already enabled.
My version of the software is 2020.4, so I guess that the fix for version 2020.2 is already included, am I right?
Message 68 of 76
GABolz
Observer
Observer
@gretaricciolini @I’m using 2022.3 and had this error. Have you tried unchecking the Unfold3D plug-in and leaving it that way? For some reason this issue comes and goes for me in my project, but when I turn off the plug in, I no longer have the issue. Maybe it’ll work for you.
Message 69 of 76
ankit.das4
works like a charm for ryzen 3700x
Message 70 of 76
kuldeep.sh2k
Observer
Observer
It's doesn't working
Message 71 of 76
Christoph_Schaedl
And? We need more info to help.
https://linktr.ee/cg_oglu
Message 72 of 76
ginokiba
Community Visitor
Community Visitor
Message 73 of 76
eremus1979
Community Visitor
Community Visitor
Autodesk is responsible for the feature working properly not Ryzen.
Message 74 of 76
rakha.adhyasta
Wow, this is a game-changer. This software is so broken lol. It worked for me too. Thank you!
Message 75 of 76
corvidstudios
It seems amd cpus have problems with unfold3D, I have a second PC with an intel cpu and unfold3D works fine on that one.
Message 76 of 76
saroarjahan306
Community Visitor
Community Visitor
Well, maybe it might be useful for someone else in the future. I had the same problem while unfolding, it kept giving me the same error. So I did the check uncheck thing and it didn't work for me. So the next thing I did was I unfolded it using the Legacy option and it worked. And later I also found out that I didn't cut my mesh properly that's why I was getting that error..so when I fixed that it worked perfectly using Unfold3d option. So maybe next time anyone faces this problem..might try this
