Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Unfold3D process error
74 REPLIES 74
Message 1 of 75
staceypeck
63406 Views, 74 Replies
I'm trying to unfold my UV map and I keep getting an error that says "// Error: Unfold3D process error." How can I resolve this?
74 REPLIES 74
Message 61 of 75
imstudent1712
in reply to: consrojo
same error keep coming me i do also have ryzen 3
Message 62 of 75
interactm
in reply to: staceypeck
from a previous reply:
there is a solution... you need to edit maya.env and add this line.
"MAYA_USE_ALTERNATE_UNFOLD_SHIM = 1"
Message 63 of 75
in reply to: sean.heasley
Do you have any other solutions to this at all?
KayT
Message 64 of 75
pathadedhiraj1
It worked for me too. BTW i am using ryzen 3700X
Message 65 of 75
bali.shotgrid
For people with the same problem. I find out the error comes from the uv shell with about 90 degree shape in the 3d mesh, try to cut more in the corner, even if this smooth rounded, when the degree is more than 90 overall will make the error, unfold shell by shell until all faces is unwraped, and sew the uv's  using Stitch Together tool until we archiving the desired result, hope it's help
Message 66 of 75
GABolz
@Anonymous Thank you! This worked for me. Not sure why, but thanks for posting your solution!
Message 67 of 75
Hi, I'm new to Maya, I'm using Maya LT for an assignment and I have this error everytime I use unfold, optimize or even layout. I'm not able to texture the asset properly and importing it in unity.
I tried your solution, but it doesn't help as Unfold3D is already enabled.
My version of the software is 2020.4, so I guess that the fix for version 2020.2 is already included, am I right?
Message 68 of 75
GABolz
in reply to: gretaricciolini
@gretaricciolini @I’m using 2022.3 and had this error. Have you tried unchecking the Unfold3D plug-in and leaving it that way? For some reason this issue comes and goes for me in my project, but when I turn off the plug in, I no longer have the issue. Maybe it’ll work for you.
Message 69 of 75
ankit.das4
works like a charm for ryzen 3700x
Message 70 of 75
kuldeep.sh2k
It's doesn't working
Message 71 of 75
And? We need more info to help.
https://linktr.ee/cg_oglu
Message 72 of 75
ginokiba
in reply to: mspeer
Message 73 of 75
eremus1979
in reply to: Samsam2019
Autodesk is responsible for the feature working properly not Ryzen.
Message 74 of 75
rakha.adhyasta
Wow, this is a game-changer. This software is so broken lol. It worked for me too. Thank you!
Message 75 of 75
corvidstudios
It seems amd cpus have problems with unfold3D, I have a second PC with an intel cpu and unfold3D works fine on that one.
