Unfold3D process error
staceypeck
Message 1 of 76
staceypeck
I'm trying to unfold my UV map and I keep getting an error that says "// Error: Unfold3D process error." How can I resolve this?
Replies (75)
Message 21 of 76
I have the same problem with ryzen 5 3600.
Message 22 of 76
autodeskriper
Same problem on Ryzen 3600. With i7 there were no problems never
Autodesk, what we have to do?
Message 23 of 76
interactm
This looks like an AMD issue. My 3990x gives me the error, whereas, my xeon works just fine. Hopefully a fix will come soon.
Message 24 of 76
3700x same problem. Fix this ! please ASAP:
Message 25 of 76
Have the same problem. Any solution from AutoDesk? Have Ryzen 3700 too
Message 26 of 76
fowlert
We are aware of the problem and are working on a fix.  Hope to get something out in an Update for released versions of Maya, and will report back here when we have something to test.
Message 27 of 76
fowlert
And it looks like 2019.3 was just made available:  https://help.autodesk.com/view/MAYAUL/2019/ENU/?guid=Maya_ReleaseNotes_2019_3_release_notes_html
That contains a change that we hope fixes this Unfold3D error but you need to set an environment variable in order to try out the fix.  Hopefully anyone that has access to 2019.3 can give it a shot and report back if it fixes things for them.
We are not ignoring other releases of Maya that also have this problem, but I have no announcements for anything else just yet.
Message 28 of 76
Samsam2019
What is an environment variable?
Message 29 of 76
Finally, it's working, guys on my Ryzen 3900X
You have to go to your pref directory, for example C:\Users\<yourname>\Documents\maya\2019 and in Maya.env file add: MAYA_USE_ALTERNATE_UNFOLD_SHIM = 1
Restart and enjoy)
Message 30 of 76
consrojo
are you using maya or maya lt?
tks in advanced.
Message 31 of 76
pedro_masa
Observer
Observer
Don´t works on maya 2018 Ryzen 3950X 😞
Message 32 of 76
T0M0X
Of course it doesn't work, because this fix was made only for Maya 2019 Update 3.
BUT there is a chance it will work if Maya 2018 is using Unfold3D as standalone application i.e. as exe.
(I can't verify it, because I don't have 2018 installed)
Go to C:\Program Files\Autodesk\Maya2018\bin and if you can find file UnfoldShim.exe you can use THIS FIX
Message 33 of 76
consrojo
its for maya or maya lt?
tks.
Message 34 of 76
Samsam2019
Thank you!
That worked! Now I hope it will come to Maya 2020 soon so I do not have to juggle between versions just to UV edit.
Message 35 of 76
sebastien.dusart
The problem is still here on Maya 2020
I have an AMD Ryzen 7 3700X Processor and a NVidia GeForce GTX 1660 Ti graphic card.
This is really annoying !!
Message 36 of 76
homkahom0
Have the same issue on Ryzen 3600, update didnt helped. ext file - too
Message 37 of 76
Im with the same problem and I chance my I7 for the amd ryzen 9 3900x, a install and reinstal maya many times, i tray the plugin manager and anything worked...Im a teacher of maya anda this happen during my class, Please autodesk solve this for us!
Message 38 of 76
Message 39 of 76
consrojo
it works, just replace those files in maya bins directory, ryzen 7 3700x (maya 2019).
Message 40 of 76
davidecruza
FOR RYZEN USERS
I found this in a forum, it works for Ryzen 3, Ryzen 5, Ryzen 7, Ryzen 9, and Ryzen Threadripper!
"I took a closer look and it looks like it is using some kind of 2017 version of Unfold (assuming by the name of the new file that appeared in bin folder of Update 3)
There are two new files in Update 3 for Maya 2019:
unfold3dlib.dll - 99.8MB - sha1 a9799263f360ed3c860980c986aefd5031fe0591
UnfoldShim2017.exe - 122kB - sha1 38a508efe9df78ab8b8f4bfc54edac7628bdc48c
So there is a way how to run Unfold3D in Maya 2020.1 now (if you are running on Ryzen or Threadripper):
1.  download and extract unfold.rar
2. copy and replace files in C:\Program Files\Autodesk\Maya2020\bin
(UnfoldShim2017.exe is already renamed to UnfoldShim.exe, so you just need to replace the file, consider backup the original)
Also I did some quick test with unfolding teddy bear model, most UVs were unfolded with just slightly difference and one UV shell wasn't unfolded properly.
Personally I would be happier with 1:1 result but it is still better than nothing or Legacy mode."
