Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Unfold3D process error
75 REPLIES 75
Message 1 of 76
staceypeck
64565 Views, 75 Replies
I'm trying to unfold my UV map and I keep getting an error that says "// Error: Unfold3D process error." How can I resolve this?
75 REPLIES 75
Message 2 of 76
sean.heasley
in reply to: staceypeck
Hi @staceypeck  and welcome to the community!
If you go to Windows->Settings/Plugins->Plugin Manager can you check and make sure you have Unfold3d enabled?
If it is already enabled, you'll want to uncheck it then recheck and try to unwrap.
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
Message 3 of 76
staceypeck
in reply to: sean.heasley
It works!
Thank you for helping. 🙂
Message 4 of 76
sean.heasley
Awesome glad it worked for you Smiley Happy!
Message 5 of 76
vilsaum
Please, I'm facing the same error here and I've tried the step that you've mentioned but is no working for me, do you have any other idea about how can I solve it?
If I try to use Unfold, Layout and Optimize the issue appear.
I've formated my computer and it worked for a while, but after some time this issue continues to appear.
Message 6 of 76
same problem with unfold3D. i noticed a thing. i have 2 pc , one with Intel CPU i7 6950K and one with AMD Ryzen 3900X . on the i7 i have no problems with unfold 3D and it works perfectly, meanwhile on AMD it not works. i tryed to turn it off and on on plugin manager and nothing happened. i tryed also to uninstall and reinstall Maya and same... unfold 3D doesn't work.
Someone can help me?
Message 7 of 76
I have the same problem here. 3d unwraped worked perfectly but now I keep getting 3dunwrap error
Message 8 of 76
pedro_masa
Same Problem on AMD RYZEN 3700
Message 9 of 76
consrojo
in reply to: pedro_masa
same here ryzen 3700x
Message 10 of 76
Same thing with Ryzen 3900
Message 11 of 76
Same problem ryzen 3700x
Message 12 of 76
i have smae ploblem with amd 3900x
Message 13 of 76
For me to make Unfold3D work again I had to Untick Loaded and Auto load in the PlugIn Manager and keep it Unticked.....
Message 14 of 76
When I Unchecked"load" and "auto load" it works.
Don't know why but thanks
Message 15 of 76
mspeer
Hi!
@Anonymous  and @Anonymous
When you unload the Unfold3D plug-in it just uses Method: "Legacy" instead of "Unfold3D",
but even with Unfold3D plug-in loaded you can manual choose "Legacy" as Method for Unfold in the options for this tool.
Message 16 of 76
Samsam2019
I tried the steps you provided, doesn't work for me on my 3960X.
Looking at the replies, I am sure its a Ryzen issue because I never had this issue with my Intel PC which I sold.
Message 17 of 76
Samsam2019
I should also mention UV optimize gives the same error.
Message 18 of 76
matorin.evgenij
I`m using Ryzen 3900X
Try to unchek the "loaded" mark from Unfold3D in pug-in manager. It helped to fix the issue.
The auto-loaded mark is still on.
Message 19 of 76
A.Baroody
in reply to: Samsam2019
Having the same unfold error issue on an AMD Threadripper 3970x. This look to be all Ryzen/Threadripper users here. Unchecking/rechecking load/autoload in plugin preference doesnt fix it.
Message 20 of 76
mspeer
in reply to: matorin.evgenij
Hi!
Again.
Unchecking Loaded for the plug-in does NOT fix it, it just disables the plug-in and switches to "Legacy" instead of "Unfold3D" mode.
Having Auto load enabled has no impact on the current Maya session, it just auto loads the plug-in with the next Maya start.
