Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Playblast not working
10 REPLIES 10
Message 1 of 11
caezekiel1990
1127 Views, 10 Replies
Hello, I am trying to create a Playblast for a class assignment and it is not working. It has worked before, and I am not sure why it is not working now. I have set the parameters to 1 to 120 and I am trying to render from camera1. I am creating a turntable of my model and I cannot create the playblast.
10 REPLIES 10
Message 2 of 11
Hi @caezekiel1990
What version of Maya are you working with and is it up to date?
Also what happens when you create the playblast? Do you get any errors?
Message 3 of 11
I am using Maya 2018. And when i click playblast I get an error message
that says missing parameter: view_transform. Program crashes right after
that.
Message 4 of 11
Hi @caezekiel1990
When Maya crashes does it generate an error report for you to submit to Autodesk? If so, please fill it out and let me know what the CER report number is!
Also you may want to double check and make sure you are on the most recent version of Arnold for Maya.
Message 5 of 11
sean.heasley
in reply to: sean.heasley
Hi @caezekiel1990
Just wanted to check in to see how things were going. Are you still having this issue?
If your issue is resolved, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Message 6 of 11
I am still having the issue. I can't even do a batch render now. I had to
record my animation on screen for my assignment. I don't know what else to
do get it fixed.
Message 7 of 11
Hi @caezekiel1990
Are you getting a crash report?
What GPU are you using and is the driver version the same as our certified hardware list?
You can find our certified hardware list here!
Also did you check your Arnold version?
Message 8 of 11
Hi @caezekiel1990
Hope you are doing well! I wanted to check in and see how things were going. Are you still experiencing this issue? Do any of @sean.heasley 's questions above need clarification?
Thanks again for being a part of our community!
Jordan Giboney
Technical Solutions Engineer | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
Message 9 of 11
The problem is still occurring.
Message 10 of 11
HI @caezekiel1990
Thanks for your reply! Please see the following questions from @sean.heasley :
  1. Are you getting a crash report?
  2. What GPU are you using and is the driver version the same as our certified hardware list?
  3. Also, have you tried resetting your preferences to default?
I look forward to hearing your answers and getting this resolved 🙂
Jordan Giboney
Message 11 of 11
Hi @caezekiel1990
I hope you are doing well! 🙂 I wanted to check in and see if you had a chance to review the questions above, and see if any clarifications are needed. The answers to these questions will help us hone in on the root cause of this problem.
Thank you for your time, and I look forward to your reply!
Jordan Giboney
