Hello, I am trying to create a Playblast for a class assignment and it is not working. It has worked before, and I am not sure why it is not working now. I have set the parameters to 1 to 120 and I am trying to render from camera1. I am creating a turntable of my model and I cannot create the playblast.
What version of Maya are you working with and is it up to date?
Also what happens when you create the playblast? Do you get any errors?
All the best,
Sean Heasley
Technical Support Specialist
Autodesk Here to Help | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Installation and Licensing Forum | Maya Certified Hardware |
When Maya crashes does it generate an error report for you to submit to Autodesk? If so, please fill it out and let me know what the CER report number is!
Also you may want to double check and make sure you are on the most recent version of Arnold for Maya.
All the best,
Sean Heasley
Just wanted to check in to see how things were going. Are you still having this issue?
If your issue is resolved, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
All the best,
Sean Heasley
Are you getting a crash report?
What GPU are you using and is the driver version the same as our certified hardware list?
You can find our certified hardware list here!
Also did you check your Arnold version?
All the best,
Sean Heasley
Hope you are doing well! I wanted to check in and see how things were going. Are you still experiencing this issue? Do any of @sean.heasley 's questions above need clarification?
Thanks again for being a part of our community!
Jordan Giboney
Technical Solutions Engineer | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
Thanks for your reply! Please see the following questions from @sean.heasley :
I look forward to hearing your answers and getting this resolved 🙂
Jordan Giboney
I hope you are doing well! 🙂 I wanted to check in and see if you had a chance to review the questions above, and see if any clarifications are needed. The answers to these questions will help us hone in on the root cause of this problem.
Thank you for your time, and I look forward to your reply!
Jordan Giboney
