- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hey all I just installed Maya 2018 at work and the script editor comes up small, missing buttons, and missing file menu options. I have pasted a picture below to show you what I see when I click 'Windows > General Editors > Script Editor'
script editor broken
So this does not look right so here are the steps I took to try and resolve this with no luck so fare:
1) In the Mel line at the bottom I pasted the following: "deleteUI scriptEditorPanel1;buildNewSceneUI;" This sadly did not work after running this because I still got the window that you see above.
2) Closed maya and renamed the prefs folder (C:\Users\aquamen\Documents\maya\2018\prefs) to prefs_old and restarted maya to force it to re build the prefs folder and in turn reset my panel/window preferences. This did not work still have the same problem.
3) Closed maya and renamed the 2018 folder (C:\Users\aquamen\Documents\maya\2018) to 2018_old to force maya to rebuild all its folders from scratch when launching maya. This did not work still have the same problem.
4) Reinstalled Maya 2018 after removing the program. Still have this problem in Maya 2018.
So whats going on? Short of re imaging the machine I don't rly see a way around this problem at this point. I have about ran out of ideas on how to solve this issue. I am working with Maya 2018 on Windows 10 Home at work. I have admin privileges on this machine as well and am signed into a admin account.
This is what I get when I launch maya for the first time in the script editor but I do not see anything that would suggest why this is happening:
// Warning: file: C:/Program Files/Autodesk/Maya2018/scripts/others/mayaHasRenderSetup.mel line 48: Failed to run file: C:/Program Files/Autodesk/Maya2018/bin/plug-ins/renderSetup.py //
// Error: file: C:/Program Files/Autodesk/Maya2018/scripts/others/mayaHasRenderSetup.mel line 48: (renderSetup) //
file -f -new;
// Warning: file: C:/Program Files/Autodesk/Maya2018/scripts/startup/rememberViewportSettings.mel line 29: Active stereo does not work with Aero enabled. Active stereo has been disabled. //
// untitled //
commandPort -securityWarning -name commandportDefault;
onSetCurrentLayout "Maya Classic";
// AbcExport v1.0 using Alembic 1.5.8 (built Jul 13 2016 18:28:45)
// AbcImport v1.0 using Alembic 1.5.8 (built Jul 13 2016 18:28:45)
// Error: file: C:/Program Files/Autodesk/Maya2018/scripts/startup/autoLoadPlugin.mel line 35: initializePlugin function failed (sceneAssembly) //
// Error: Unable to execute igInitialize.mel. //
// Error: Unable to execute xgen.mel. //
// Error: file: C:/Program Files/Autodesk/Maya2018/scripts/startup/autoLoadPlugin.mel line 35: initializePlugin function failed (Type) //
updateRendererUI;
// Error: file: C:/Program Files/Autodesk/Maya2018/plug-ins/xgen/scripts/xgenUI.mel line 512: Cannot find procedure "MakeXGenHUD". //
// Warning: file: C:/Program Files/Autodesk/Maya2018/scripts/others/supportRenderers.mel line 64: The renderer "arnold" used by this scene, is not currently available. The "mayaSoftware" renderer will be used instead. //
onSetCurrentLayout "Modeling - Standard";
Thank you guys for all your help and suggestions! If I solve this on my own I will report back what I had to do so other people hopefully will find this to help them out.
