.NET Version for Inventor 2019
2 REPLIES 2
AlexFielder
3289 Views, 2 Replies
Hi all,
I did perform a quick search but the answer didn't jump out at me so:
What's the highest version of .NET we should use with Inventor 2019?
I know from previous posts that Inventor 2018 uses .NET 4.6, so I assume 2019 will be the same or maybe .NET 4.6.#?
Can @bob_holland or one of the team confirm?
Alex.
2 REPLIES 2
See this:
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/sfdcarticles/sfdcarticle...
.NET Framework.NET Framework Version 4.7 or later. Windows Updates enabled for installation.
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
bob_holland
in reply to: AlexFielder
@AlexFielder,
Thank you for the mention.
@bradeneuropeArthur is correct on needing .NET 4.7.
Here is a link to:
Microsoft .NET Framework 4.7.1 (Offline Installer) for Windows 7 SP1, Windows 8.1, Windows 10 Anniversary Update, Windows 10 Creators Update, Windows Server 2008 R2 SP1, Windows Server 2012, Windows Server 2012 R2 and Windows Server 2016
https://www.microsoft.com/en-us/download/details.aspx?id=56116
Thank you all for using Inventor and have a great rest of your week.
Bob Holland
Autodesk Product Support
Technology Administrators
