Hi all,
I did perform a quick search but the answer didn't jump out at me so:
What's the highest version of .NET we should use with Inventor 2019?
I know from previous posts that Inventor 2018 uses .NET 4.6, so I assume 2019 will be the same or maybe .NET 4.6.#?
Can @bob_holland or one of the team confirm?
Alex.
Solved by bob_holland. Go to Solution.
Solved by bradeneuropeArthur. Go to Solution.
See this:
.NET Framework | .NET Framework Version 4.7 or later. Windows Updates enabled for installation. |
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
Thank you for the mention.
@bradeneuropeArthur is correct on needing .NET 4.7.
Here is a link to:
Microsoft .NET Framework 4.7.1 (Offline Installer) for Windows 7 SP1, Windows 8.1, Windows 10 Anniversary Update, Windows 10 Creators Update, Windows Server 2008 R2 SP1, Windows Server 2012, Windows Server 2012 R2 and Windows Server 2016
https://www.microsoft.com/en-us/download/details.aspx?id=56116
Thank you all for using Inventor and have a great rest of your week.
