Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
length, width, and height of a assembly?
10 REPLIES 10
Message 1 of 11
2211 Views, 10 Replies
Hi everyone!
I would like to determine the length, width, and height of a assembly.
Can i use the bounding box method to do this, or the range box?
Can anyone give a example?
Thansk.
10 REPLIES 10
Message 2 of 11
AssemblyComponentDefinition.RangeBox should give you these extents. These
extents include things such as sketches and work features. If you don't want
those included, you'll need to iterate over all bodies in the leaf parts and
build your own range box.
Sanjay-
wrote in message news:5781503@discussion.autodesk.com...
Hi everyone!
Thansk.
Message 3 of 11
eh?
Message 4 of 11
need help ...
Message 5 of 11
Recently I needed the same thing, here the snippet code:
Sub GetBoundingBox()
    Dim ass As AssemblyDocument
    Set ass = ThisApplication.ActiveDocument
    Dim min_point(1 To 3) As Double
    Dim max_point(1 To 3) As Double
    Call ass.ComponentDefinition.RangeBox.GetBoxData(min_point, max_point)
    Debug.Print min_point(1) & " " & min_point(2) & " " & min_point(3)
    Debug.Print max_point(1) & " " & max_point(2) & " " & max_point(3)
End Sub
maybe is useful for someone else. Bye
P
Message 6 of 11
bradeneuropeArthur
Is this solved now?
Or do you need further assistance?
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
Message 7 of 11
in reply to: bradeneuropeArthur
It's solved on my snippet. There are otherways?
Message 8 of 11
bradeneuropeArthur
I can provide you My/the coding if needed.
Arthur Knoors
Message 9 of 11
This may be an interesting idea:
https://forums.autodesk.com/t5/inventor-ideas/dimension-component-part-and-assembly/idi-p/7523011
Arthur Knoors
Tags (1)
Message 10 of 11
felipeecheverri
hi, use this ilogic
	MaxL = Round (Measure.ExtentsLength,0)
	MaxW = Round (Measure.ExtentsWidth,0)
	MaxH = Round (Measure.ExtentsHeight,0)
Message 11 of 11
it works, thanks
