Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Auto Drawing Rolling check measurements, Issues with ilogic Intersection points.
3 REPLIES 3
roy_pridham
303 Views, 3 Replies
roy_pridham
Hello, got stuff with some ilogic code, I'm trying to create 3 lines with ilogic cade and its harder then expected.
I find myself drawing the same sketch 20 - 30 times a day and i want to automate it.
Any ideas of pointers as to where too from here i would be glad to know.
I'm stuck i cant seem to find the intersection point on the curve using the circles.
This is what i want to draw, 1m straight line from Arc start point and 2m straight line from Arc End point touching the curve:
This is the code i have done so far:
Sub Main()
    ' Prompt the user to select a view in the drawing
    Dim oView As DrawingView
    oView = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "Select a view")
    ' Check if a view was selected
    If oView Is Nothing Then
        MessageBox.Show("No view selected. Exiting script.")
        Exit Sub
    ' Create a sketch in the selected view
    Dim oSketch As DrawingSketch
    oSketch = oView.Sketches.Add()
    ' Project all entities in the view onto the sketch
    Dim oDrawingCurves As DrawingCurvesEnumerator
    oDrawingCurves = oView.DrawingCurves
    Dim oProjectedEntities As ObjectCollection
    oProjectedEntities = ThisApplication.TransientObjects.CreateObjectCollection()
    For Each oCurve As DrawingCurve In oDrawingCurves
        oProjectedEntities.Add(oSketch.AddByProjectingEntity(oCurve))
    Next
    ' Open the sketch for editing
    oSketch.Edit()
    ' Prompt the user to select a curve in the sketch
    Dim oSelectedEntity As Object
    oSelectedEntity = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kSketchCurveFilter, "Select a curve")
    ' Check if the selected entity is a SketchArc or SketchLine
    Dim oSelectedCurve As SketchEntity
    If TypeOf oSelectedEntity Is SketchArc Or TypeOf oSelectedEntity Is SketchLine Then
        oSelectedCurve = oSelectedEntity
        ' Get the start and end points of the selected curve
        Dim oStartPoint As Point2d
        Dim oEndPoint As Point2d
        If TypeOf oSelectedCurve Is SketchArc Then
            oStartPoint = CType(oSelectedCurve, SketchArc).StartSketchPoint.Geometry
            oEndPoint = CType(oSelectedCurve, SketchArc).EndSketchPoint.Geometry
        ElseIf TypeOf oSelectedCurve Is SketchLine Then
            oStartPoint = CType(oSelectedCurve, SketchLine).StartSketchPoint.Geometry
            oEndPoint = CType(oSelectedCurve, SketchLine).EndSketchPoint.Geometry
        ' Create a circle at the start point of the selected curve with radius 2000 mm (2 meters)
        Dim radiusStart As Double = 2000.0 ' in mm
        Dim oCircleStart As SketchCircle
        oCircleStart = oSketch.SketchCircles.AddByCenterRadius(oStartPoint, radiusStart)
        ' Create a circle at the end point of the selected curve with radius 1000 mm (1 meter)
        Dim radiusEnd As Double = 1000.0 ' in mm
        Dim oCircleEnd As SketchCircle
        oCircleEnd = oSketch.SketchCircles.AddByCenterRadius(oEndPoint, radiusEnd)
        ' Draw a line between the start and end points of the selected curve
        oSketch.SketchLines.AddByTwoPoints(oStartPoint, oEndPoint)
    Else
        MessageBox.Show("The selected entity is not a curve.")
        oSketch.ExitEdit()
        Exit Sub
    ' Exit sketch edit mode
    oSketch.ExitEdit()
End Sub
This is what it draws:
Sub Main()
        Exit Sub
    Next
    oSketch.Edit()
    Else
        oSketch.ExitEdit()
        Exit Sub
    oSketch.ExitEdit()
End Sub
3 REPLIES 3
JelteDeJong
in reply to: roy_pridham
JelteDeJong
you could try something like this. I have drawn the circle just like you but instead of getting the intersection point I constraint the line to the circle and then to the selected curve. (Also keep in mind that the Inventor API works with cm instead of mm)
Sub Main()
    Dim doc As DrawingDocument = ThisDoc.Document
    Dim sheet As Sheet = doc.ActiveSheet
    Dim curveSegment As DrawingCurveSegment = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingCurveSegmentFilter, "")
    Dim curve As DrawingCurve = curveSegment.Parent
    Dim view As DrawingView = curve.Parent
    Dim sketch As DrawingSketch = view.Sketches.Add()
    Dim sketchCurve = sketch.AddByProjectingEntity(curve)
    If TypeOf sketchCurve Is SketchArc Or TypeOf sketchCurve Is SketchLine Then
        sketch.Edit()
        Dim startSketchPoint As SketchPoint
        Dim endSketchPoint As SketchPoint
        If TypeOf sketchCurve Is SketchArc Then
            startSketchPoint = CType(sketchCurve, SketchArc).StartSketchPoint
            endSketchPoint = CType(sketchCurve, SketchArc).EndSketchPoint
        ElseIf TypeOf sketchCurve Is SketchLine Then
            startSketchPoint = CType(sketchCurve, SketchLine).StartSketchPoint
            endSketchPoint = CType(sketchCurve, SketchLine).EndSketchPoint
        DrawLine(sketch, startSketchPoint, sketchCurve, 200)
        DrawLine(sketch, endSketchPoint, sketchCurve, 100)
        sketch.ExitEdit()
    Else
End Sub
Private Sub DrawLine(sketch As DrawingSketch, point As SketchPoint, curve As SketchEntity, Length As Double)
    Dim circle As SketchCircle = sketch.SketchCircles.AddByCenterRadius(point, Length)
    circle.SketchOnly = True
    sketch.GeometricConstraints.AddCoincident(circle.CenterSketchPoint, point)
    sketch.DimensionConstraints.AddDiameter(circle, circle.CenterSketchPoint.Geometry)
    Dim orign = ThisApplication.TransientGeometry.CreatePoint2d(0, 0)
    Dim l1 = sketch.SketchLines.AddByTwoPoints(point, orign)
    sketch.GeometricConstraints.AddCoincident(l1.EndSketchPoint, curve)
    sketch.GeometricConstraints.AddCoincident(l1.EndSketchPoint, circle)
End Sub
Jelte de Jong
Blog: hjalte.nl - github.com
Sub Main()
        sketch.Edit()
        sketch.ExitEdit()
    Else
End Sub
End Sub
Jelte de Jong
roy_pridham
roy_pridham
THANK YOU VERY MUCH 😎. I have spent way to long trying to get this to work.
Stakin
in reply to: JelteDeJong
Stakin
Sub Main()
        sketch.Edit()
        sketch.ExitEdit()
    Else
End Sub
	Dim oP02d As Point2d
	Dim oX1 As Double
	Dim oY1 As Double
	oX1 = (curve.RangeBox.MaxPoint.X + curve.RangeBox.MinPoint.X) / 2
	oY1 = (curve.RangeBox.MaxPoint.Y + curve.RangeBox.MinPoint.Y) / 2
	oP02d=ThisApplication.TransientGeometry.CreatePoint2d(oX1,oY1)
    Dim l1 = sketch.SketchLines.AddByTwoPoints(point, oP02d)
	Dim oSkd As Inventor.TwoPointDistanceDimConstraint
	oSkd=sketch.DimensionConstraints.AddTwoPointDistance(l1.EndSketchPoint, l1.StartSketchPoint, DimensionOrientationEnum.kAlignedDim, oP02d)
	oSkd.Parameter.Expression=Length*10
        sketch.Solve
End Sub
a little modify of sub Drawline,don't need create the circle
Sub Main()
        sketch.Edit()
        sketch.ExitEdit()
    Else
End Sub
	Dim oX1 As Double
	Dim oY1 As Double
        sketch.Solve
End Sub
