Hello, got stuff with some ilogic code, I'm trying to create 3 lines with ilogic cade and its harder then expected.
I find myself drawing the same sketch 20 - 30 times a day and i want to automate it.
Any ideas of pointers as to where too from here i would be glad to know.
I'm stuck i cant seem to find the intersection point on the curve using the circles.
This is what i want to draw, 1m straight line from Arc start point and 2m straight line from Arc End point touching the curve:
This is the code i have done so far:
Sub Main()
' Prompt the user to select a view in the drawing
Dim oView As DrawingView
oView = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "Select a view")
' Check if a view was selected
If oView Is Nothing Then
MessageBox.Show("No view selected. Exiting script.")
Exit Sub
End If
' Create a sketch in the selected view
Dim oSketch As DrawingSketch
oSketch = oView.Sketches.Add()
' Project all entities in the view onto the sketch
Dim oDrawingCurves As DrawingCurvesEnumerator
oDrawingCurves = oView.DrawingCurves
Dim oProjectedEntities As ObjectCollection
oProjectedEntities = ThisApplication.TransientObjects.CreateObjectCollection()
For Each oCurve As DrawingCurve In oDrawingCurves
oProjectedEntities.Add(oSketch.AddByProjectingEntity(oCurve))
Next
' Open the sketch for editing
oSketch.Edit()
' Prompt the user to select a curve in the sketch
Dim oSelectedEntity As Object
oSelectedEntity = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kSketchCurveFilter, "Select a curve")
' Check if the selected entity is a SketchArc or SketchLine
Dim oSelectedCurve As SketchEntity
If TypeOf oSelectedEntity Is SketchArc Or TypeOf oSelectedEntity Is SketchLine Then
oSelectedCurve = oSelectedEntity
' Get the start and end points of the selected curve
Dim oStartPoint As Point2d
Dim oEndPoint As Point2d
If TypeOf oSelectedCurve Is SketchArc Then
oStartPoint = CType(oSelectedCurve, SketchArc).StartSketchPoint.Geometry
oEndPoint = CType(oSelectedCurve, SketchArc).EndSketchPoint.Geometry
ElseIf TypeOf oSelectedCurve Is SketchLine Then
oStartPoint = CType(oSelectedCurve, SketchLine).StartSketchPoint.Geometry
oEndPoint = CType(oSelectedCurve, SketchLine).EndSketchPoint.Geometry
End If
' Create a circle at the start point of the selected curve with radius 2000 mm (2 meters)
Dim radiusStart As Double = 2000.0 ' in mm
Dim oCircleStart As SketchCircle
oCircleStart = oSketch.SketchCircles.AddByCenterRadius(oStartPoint, radiusStart)
' Create a circle at the end point of the selected curve with radius 1000 mm (1 meter)
Dim radiusEnd As Double = 1000.0 ' in mm
Dim oCircleEnd As SketchCircle
oCircleEnd = oSketch.SketchCircles.AddByCenterRadius(oEndPoint, radiusEnd)
' Draw a line between the start and end points of the selected curve
oSketch.SketchLines.AddByTwoPoints(oStartPoint, oEndPoint)
Else
MessageBox.Show("The selected entity is not a curve.")
oSketch.ExitEdit()
Exit Sub
End If
' Exit sketch edit mode
oSketch.ExitEdit()
End Sub
This is what it draws:
Sub Main()
Exit Sub
End If
Next
oSketch.Edit()
End If
Else
oSketch.ExitEdit()
Exit Sub
End If
oSketch.ExitEdit()
End Sub
Solved by JelteDeJong. Go to Solution.
you could try something like this. I have drawn the circle just like you but instead of getting the intersection point I constraint the line to the circle and then to the selected curve. (Also keep in mind that the Inventor API works with cm instead of mm)
Sub Main()
Dim doc As DrawingDocument = ThisDoc.Document
Dim sheet As Sheet = doc.ActiveSheet
Dim curveSegment As DrawingCurveSegment = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingCurveSegmentFilter, "")
Dim curve As DrawingCurve = curveSegment.Parent
Dim view As DrawingView = curve.Parent
Dim sketch As DrawingSketch = view.Sketches.Add()
Dim sketchCurve = sketch.AddByProjectingEntity(curve)
If TypeOf sketchCurve Is SketchArc Or TypeOf sketchCurve Is SketchLine Then
sketch.Edit()
Dim startSketchPoint As SketchPoint
Dim endSketchPoint As SketchPoint
If TypeOf sketchCurve Is SketchArc Then
startSketchPoint = CType(sketchCurve, SketchArc).StartSketchPoint
endSketchPoint = CType(sketchCurve, SketchArc).EndSketchPoint
ElseIf TypeOf sketchCurve Is SketchLine Then
startSketchPoint = CType(sketchCurve, SketchLine).StartSketchPoint
endSketchPoint = CType(sketchCurve, SketchLine).EndSketchPoint
End If
DrawLine(sketch, startSketchPoint, sketchCurve, 200)
DrawLine(sketch, endSketchPoint, sketchCurve, 100)
sketch.ExitEdit()
Else
End If
End Sub
Private Sub DrawLine(sketch As DrawingSketch, point As SketchPoint, curve As SketchEntity, Length As Double)
Dim circle As SketchCircle = sketch.SketchCircles.AddByCenterRadius(point, Length)
circle.SketchOnly = True
sketch.GeometricConstraints.AddCoincident(circle.CenterSketchPoint, point)
sketch.DimensionConstraints.AddDiameter(circle, circle.CenterSketchPoint.Geometry)
Dim orign = ThisApplication.TransientGeometry.CreatePoint2d(0, 0)
Dim l1 = sketch.SketchLines.AddByTwoPoints(point, orign)
sketch.GeometricConstraints.AddCoincident(l1.EndSketchPoint, curve)
sketch.GeometricConstraints.AddCoincident(l1.EndSketchPoint, circle)
End Sub
Jelte de Jong
Blog: hjalte.nl - github.com
Sub Main()
sketch.Edit()
End If
sketch.ExitEdit()
Else
End If
End Sub
End Sub
Jelte de Jong
THANK YOU VERY MUCH 😎. I have spent way to long trying to get this to work.
Sub Main()
sketch.Edit()
End If
sketch.ExitEdit()
Else
End If
End Sub
Dim oP02d As Point2d
Dim oX1 As Double
Dim oY1 As Double
oX1 = (curve.RangeBox.MaxPoint.X + curve.RangeBox.MinPoint.X) / 2
oY1 = (curve.RangeBox.MaxPoint.Y + curve.RangeBox.MinPoint.Y) / 2
oP02d=ThisApplication.TransientGeometry.CreatePoint2d(oX1,oY1)
Dim l1 = sketch.SketchLines.AddByTwoPoints(point, oP02d)
Dim oSkd As Inventor.TwoPointDistanceDimConstraint
oSkd=sketch.DimensionConstraints.AddTwoPointDistance(l1.EndSketchPoint, l1.StartSketchPoint, DimensionOrientationEnum.kAlignedDim, oP02d)
oSkd.Parameter.Expression=Length*10
sketch.Solve
End Sub
a little modify of sub Drawline,don't need create the circle
Sub Main()
sketch.Edit()
End If
sketch.ExitEdit()
Else
End If
End Sub
Dim oX1 As Double
Dim oY1 As Double
sketch.Solve
End Sub
