Recently I needed the same thing, here the snippet code:
Sub GetBoundingBox() Dim ass As AssemblyDocument Set ass = ThisApplication.ActiveDocument Dim min_point(1 To 3) As Double Dim max_point(1 To 3) As Double Call ass.ComponentDefinition.RangeBox.GetBoxData(min_point, max_point) Debug.Print min_point(1) & " " & min_point(2) & " " & min_point(3) Debug.Print max_point(1) & " " & max_point(2) & " " & max_point(3) End Sub
maybe is useful for someone else. Bye
P
P
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Arthur Knoors
It's solved on my snippet. There are otherways?
I can provide you My/the coding if needed.
Arthur Knoors
Arthur Knoors
This may be an interesting idea:
https://forums.autodesk.com/t5/inventor-ideas/dimension-component-part-and-assembly/idi-p/7523011
Arthur Knoors
Arthur Knoors
hi, use this ilogic
MaxL = Round (Measure.ExtentsLength,0) MaxW = Round (Measure.ExtentsWidth,0) MaxH = Round (Measure.ExtentsHeight,0)
hi, use this ilogic
it works, thanks
