Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
How to send iProperties to all parts of Assembly and his Sub-Assemblies
8 REPLIES 8
Message 1 of 9
2839 Views, 8 Replies
The code below is sending some iproperties to the different parts of the assembly, now I have placed some sub-assemblies as well but the code is not taking in consideration the parts of those sub-assemblies to send the iproperties, can somebody help me to correct the code so it does that as well. basically to send the iproperties in the code to all parts in the assembly and to all the parts of the different sub-assemblies as well.
Thanks in advance
Here is the code:
SyntaxEditor Code Snippet
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
'Iterate through all Of the occurrences
Dim oOccurrence As ComponentOccurrence
For Each oOccurrence In oAsmCompDef.Occurrences.AllReferencedOccurrences(oAsmCompDef)
Try
'write to component iprops
iProperties.Value(oOccurrence, "Project", "Project") = iProperties.Value("Project", "Project")
iProperties.Value(oOccurrence, "Project", "Creation Date") = iProperties.Value("Project", "Creation Date")
iProperties.Value(oOccurrence, "Summary", "Title") = iProperties.Value("Summary", "Title")
iProperties.Value(oOccurrence, "Summary", "Company") = iProperties.Value("Summary", "Company")
iProperties.Value(oOccurrence, "Summary", "Author") = iProperties.Value("Summary", "Author")
iProperties.Value(oOccurrence, "Custom", "AVT_NUMBER") = iProperties.Value("Custom", "AVT_NUMBER")
Catch 'catch errors
	MsgBox ("ERROR WHEN MAKING LABEL")
End Try
Next
8 REPLIES 8
Message 2 of 9
bradeneuropeArthur
If the component is an assembly the code selves need to be run again. Can you upload the complete code with the routine name so we can modify it for you...
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
Message 3 of 9
MechMachineMan
For Each oOccurrence In oAsmCompDef.Occurrences.AllLeafOccurrences
    Try
    Catch 'catch errors
	MsgBox ("ERROR WHEN MAKING LABEL FOR:" & vblf & oOccurrence.Name)
    End Try
Next
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 4 of 9
in reply to: MechMachineMan
I'll try to upload the model as soon as I can, I really appreciate all of your inputs
Message 5 of 9
I got a more detailed code where everything is well passing from the model properties to his parts custom properties, sadly still not passing to the model sub-assemblies custom properties.
Could you please see how to make it work. Really appreciate your help.
Sub Main
'Gets the Active Document
oDoc = ThisDoc.Document
'Saves this document
oDoc.Save
'Checks if the active document is an assembly
If oDoc.DocumentType = kAssemblyDocumentObject
	'Gets the assembly occurrences
	Dim oOccs As ComponentOccurrences
	oOccs = oDoc.ComponentDefinition.Occurrences
	'Call the subprocedure to traverse the assembly
	Call TraverseAssembly(oOccs)
End If
End Sub
Public Sub TraverseAssembly(oOccs As ComponentOccurrences)
 'Integer to traverse the assembly occurrences
 Dim i As Integer
 For i=1 To oOccs.Count
  Dim oOcc As ComponentOccurrence
  oOcc = oOccs.Item(i)
 	If oOcc.Suppressed = False
		'Occurrence Name (Display Name)
		oOccName = oOcc.Name
		'Gets the first three leters of the Occurrence Name (e.g. "STK")
		oOccPrefix = Left(oOccName, 3)
		If oOccPrefix <> "STK"
			Try
				iProperties.Value(oOccName, "Project", "Project") = iProperties.Value("Project", "Project")
				iProperties.Value(oOccName, "Project", "Creation Date") = iProperties.Value("Project", "Creation Date")
				iProperties.Value(oOccName, "Summary", "Title") = iProperties.Value("Summary", "Title")
				iProperties.Value(oOccName, "Summary", "Company") = iProperties.Value("Summary", "Company")
				iProperties.Value(oOccName, "Summary", "Author") = iProperties.Value("Summary", "Author")
				iProperties.Value(oOccName, "Custom", "AVT_NUMBER") = iProperties.Value("Custom", "AVT_NUMBER")
				iProperties.Value(oOccName, "Custom", "CAR_NUMBER") = iProperties.Value("Custom", "CAR_NUMBER")
				iProperties.Value(oOccName, "Custom", "JOB_NAME") = iProperties.Value("Custom", "JOB_NAME")
				iProperties.Value(oOccName, "Custom", "ToPrint_AVT_NUMBER") = iProperties.Value("Custom", "ToPrint_AVT_NUMBER")
				iProperties.Value(oOccName, "Custom", "ToPrint_CAR_NUMBER") = iProperties.Value("Custom", "ToPrint_CAR_NUMBER")
				iProperties.Value(oOccName, "Custom", "ToPrint_JOB_NAME") = iProperties.Value("Custom", "ToPrint_JOB_NAME")
				iProperties.Value(oOccName, "Custom", "Path_Amada") = iProperties.Value("Custom", "Path_Amada")
				iProperties.Value(oOccName, "Custom", "Path_Laser") = iProperties.Value("Custom", "Path_Laser")
			Catch
				'It won't be able to change Read-Only parts (e.g. Content Center)
				'MessageBox.Show("This is a content center file: " & oOcc.Name, "Title")
			End Try
		End If
		If oOcc.DefinitionDocumentType = kAssemblyDocumentObject
			Call TraverseAssembly(oOcc.SubOccurrences)
		End If
	End If
Next
End Sub
Message 6 of 9
in reply to: bradeneuropeArthur
sorry it took so long... I was doing other things,
Now I have a code that is passing the main assembly custom properties to the parts, but not to the sub-assembly custom properties,
Can you help me with this? thanks,
Sub Main
oDoc.Save
End If
End Sub
 Dim i As Integer
			Try
			Catch
			End Try
		End If
		End If
	End If
Next
End Sub
Message 7 of 9
bradeneuropeArthur
Sub Main
oDoc.Save
End If
End Sub
 Dim i As Integer
 'For i=1 To oOccs.Count
For Each oOcc in oOccs 'oOcc = oOccs.Item(i) If oOcc.Suppressed = False 'Occurrence Name (Display Name) oOccName = oOcc.Name 'Gets the first three leters of the Occurrence Name (e.g. "STK") oOccPrefix = Left(oOccName, 3) If oOccPrefix <> "STK" Try iProperties.Value(oOccName, "Project", "Project") = iProperties.Value("Project", "Project") iProperties.Value(oOccName, "Project", "Creation Date") = iProperties.Value("Project", "Creation Date") iProperties.Value(oOccName, "Summary", "Title") = iProperties.Value("Summary", "Title") iProperties.Value(oOccName, "Summary", "Company") = iProperties.Value("Summary", "Company") iProperties.Value(oOccName, "Summary", "Author") = iProperties.Value("Summary", "Author") iProperties.Value(oOccName, "Custom", "AVT_NUMBER") = iProperties.Value("Custom", "AVT_NUMBER") iProperties.Value(oOccName, "Custom", "CAR_NUMBER") = iProperties.Value("Custom", "CAR_NUMBER") iProperties.Value(oOccName, "Custom", "JOB_NAME") = iProperties.Value("Custom", "JOB_NAME") iProperties.Value(oOccName, "Custom", "ToPrint_AVT_NUMBER") = iProperties.Value("Custom", "ToPrint_AVT_NUMBER") iProperties.Value(oOccName, "Custom", "ToPrint_CAR_NUMBER") = iProperties.Value("Custom", "ToPrint_CAR_NUMBER") iProperties.Value(oOccName, "Custom", "ToPrint_JOB_NAME") = iProperties.Value("Custom", "ToPrint_JOB_NAME") iProperties.Value(oOccName, "Custom", "Path_Amada") = iProperties.Value("Custom", "Path_Amada") iProperties.Value(oOccName, "Custom", "Path_Laser") = iProperties.Value("Custom", "Path_Laser") Catch 'It won't be able to change Read-Only parts (e.g. Content Center) 'MessageBox.Show("This is a content center file: " & oOcc.Name, "Title") End Try End If If oOcc.DefinitionDocumentType = kAssemblyDocumentObject Call TraverseAssembly(oOcc.SubOccurrences) End If End If Next End Sub
Arthur Knoors
Message 8 of 9
Big thanks!!!
It worked perfectly well.
Message 9 of 9
bradeneuropeArthur
Your thanks are appreciated very much.
Autodesk Software: Inventor Professional 2018 | Vault Professional 2018 | Autocad Mechanical 2018
Programming Skills: Vba | Vb.net (Add ins Vault / Inventor, Applications) | I-logic
Dimension Component! | Partlist Export! | Derive I-properties! | Vault Prompts Via API! | Vault Handbook/Manual!
Drawing Toggle Sheets! | Vault Defer Update!
Arthur Knoors
