Dears,
I'm trying to creating a dynamic button for checking something that relative to standard.
My question is: Is there any solution to change button's description/tooltip dynamic? I mean when I got an error, if error is A => Button show description/tooltip A; if B => Button show description/tooltip B...
Thanks!
The same as I have shown you with the Icon!
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Same as this:
And than specific these lines:
m_sampleButton.ToolTipText = "Other Text"
m_sampleButton.DescriptionText = "Other Text"
Private WithEvents m_sampleButton As ButtonDefinition
#Region "ApplicationAddInServer Members"
' This method is called by Inventor when it loads the AddIn. The AddInSiteObject provides access
' to the Inventor Application object. The FirstTime flag indicates if the AddIn is loaded for
' the first time. However, with the introduction of the ribbon this argument is always true.
Public Sub Activate(ByVal addInSiteObject As Inventor.ApplicationAddInSite, ByVal firstTime As Boolean) Implements Inventor.ApplicationAddInServer.Activate
' Initialize AddIn members.
g_inventorApplication = addInSiteObject.Application
' Connect to the user-interface events to handle a ribbon reset.
m_uiEvents = g_inventorApplication.UserInterfaceManager.UserInterfaceEvents
' TODO: Add button definitions.
' Sample to illustrate creating a button definition.
'Dim largeIcon As stdole.IPictureDisp = PictureDispConverter.ToIPictureDisp(My.Resources.YourBigImage)
'Dim smallIcon As stdole.IPictureDisp = PictureDispConverter.ToIPictureDisp(My.Resources.YourSmallImage)
Dim controlDefs As Inventor.ControlDefinitions = g_inventorApplication.CommandManager.ControlDefinitions
m_sampleButton = controlDefs.AddButtonDefinition("Command Name", "Internal Name", CommandTypesEnum.kShapeEditCmdType, AddInClientID)
' Add to the user interface, if it's the first time.
If firstTime Then
AddToUserInterface()
End If
End Sub
Arthur Knoors
