VBA code to change level of detail representation of assembly occurrences
Eyal.Admon
Eyal.Admon
I need to change  to change level of detail representation of certain occurrences in an assembly.
the occurrence is currently suppressed and need to change to LOD "all components suppressed"
Thanks in advance,
Eyal
bradeneuropeArthur
You want to change the LOD from sub-assemblies in a assembly, correct?
What version of Inventor are you using?
What specific occurrences do you want to change?
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
Eyal.Admon
Hi Arthur,
Thank you for your reply .
I'm currently using inventor 2019.
I'm aware that when I will upgrade, I'll have to modify my code.
I currently have a script that iterates through all the occurrences in an assembly document and looking for a specific one by name.
I managed to unsuppress an occurrence but not change to a specific LOD..
Eyal
Eyal.Admon
never mind, found out how.
her's the code:
Sub SET_LOD()
Dim oDoc As AssemblyDocument
Dim oComps As ComponentOccurrences
Dim oComp As ComponentOccurrence
Dim LOD As String
Set oDoc = ThisApplication.ActiveDocument
Set oComps = oDoc.ComponentDefinition.Occurrences
LOD = "All Parts Suppressed"
For Each oComp In oComps
  If oComp.Definition.Document.File.FullFileName = FilePath Then
   Call oComp.SetLevelOfDetailRepresentation(LOD, False)
Next
End Sub
