get vault folder properties
richterBKSAC
richterBKSAC
I want to access/get the vault properties of the folder + parent folder of an idw, located in the folder, currently openend in Inventor via ilogic.
I've found other posts about similar topics, like getting the lifecyclestatus, but I can't manage to rebuild them to do what I want.
Any help is much apprecciated.
bradeneuropeArthur
Lifecyclestatus or statehistorical
Arthur Knoors
Autodesk Affiliations:
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
richterBKSAC
Would you please elaborate on your answer, if possible? I have access to the VaultSDK.chm file too.
This is what I'm using to get the current lifecyclestate of a file.
AddReference "Autodesk.Connectivity.WebServices.dll"
Imports AWS = Autodesk.Connectivity.WebServices
AddReference "Autodesk.DataManagement.Client.Framework.Vault.dll"
Imports VDF = Autodesk.DataManagement.Client.Framework
AddReference "Connectivity.Application.VaultBase.dll"
Imports VB = Connectivity.Application.VaultBase
Sub Main()
	Dim paras As Parameters
	Dim para As Parameter
	Dim propsets As PropertySets
	Dim doc As Document = ThisDoc.Document
		Dim mVltCon As VDF.Vault.Currency.Connections.Connection
		mVltCon = VB.ConnectionManager.Instance.Connection
		If  mVltCon Is Nothing Then
		     MsgBox("Not logged in to Vault" )
		     Exit Sub
		End If
		MsgBox(get_vaultfilestatus(doc.FullFileName, mVltCon))
End Sub
Function get_vaultfilestatus(filepath As String, vaultconnection As VDF.Vault.Currency.Connections.Connection) As String
	filepath = filepath.Replace("C:\xx\", "$/")
	'flip the slashes
	filepath = filepath.Replace("\", "/")
	Dim VaultPaths() As String = New String() {filepath}
	Dim wsFiels() As AWS.File = vaultconnection.WebServiceManager.DocumentService.FindLatestFilesByPaths(VaultPaths)
	Dim mFileIt As VDF.Vault.Currency.Entities.FileIteration = New VDF.Vault.Currency.Entities.FileIteration(conn,wsFiels(0))
	Dim lifeCycleInfo As VDF.Vault.Currency.Entities.FileLifecycleInfo = mFileIt.LifecycleInfo
	Return lifeCycleInfo.StateName
	'MessageBox.Show(lifeCycleInfo.StateName)
End Function
richterBKSAC
I've been digging a little in the VaultSDK.chm file and found a possible route, although I don't know to put it into code yet. Maybe someone could tell me if this route would be possible and/or provide some code.
  1. get the entityID of the active Inventor file
  2. get the FolderID of the parent folder (from the file class)
    1. use GetPropertiesByEntityIds (PropertyService class) to get the desired property values
  3. get the ParID with the FolderID (Folder class) to get the ID of the folder above the current folder
    1. repeat step 2.1
richterBKSAC
For future users, here is how I managed to get the property value of a vault property attached to a folder in vault.
AddVbFile "iLogic_Basis.vb"
Sub Main()
	'Vault Connection
	     MsgBox("Not logged into Vault",,"Error" )
	     Exit Sub
	End If
	'insert the property name as string
	vault_get_folder_prop(doc.FullFileName, mVltCon, "yourPropertyName")
End Sub
Function vault_get_folder_prop(filepath As String, vaultconnection As VDF.Vault.Currency.Connections.Connection, propname As String) As String
	'complete the path to your local vault working directory
	filepath = filepath.Replace("C:\XX\", "$/")
	'flip the slashes
	Dim wsFiles() As AWS.File = vaultconnection.WebServiceManager.DocumentService.FindLatestFilesByPaths(VaultPaths)
	Dim mFileIt As AWS.File = New VDF.Vault.Currency.Entities.FileIteration(conn, wsFiles(0))
	'get the folder ID of the folder your currently opened Inventor file is located in
	Dim folderid As Long = mFileIt.FolderId
	'get the property definition ID of your desired property
	Dim pdefs() As AWS.PropDef = vaultconnection.WebServiceManager.PropertyService.GetPropertyDefinitionsByEntityClassId("FLDR")
	Dim propdef_ID As Long
	For Each propdef In pdefs
		If propdef.DispName = propname Then
			propdef_ID = propdef.Id
		End If
	Next
	'get the property value of your desired property
	Dim propValues As AWS.PropInst() = vaultconnection.WebServiceManager.PropertyService.GetProperties("FLDR", New Long(){folderid},New Long(){propdef_ID})
	Dim propValue As String = DirectCast(propValues(0).Val, String)
	Return propValue
End Function
