richterBKSAC
in reply to: richterBKSAC
For future users, here is how I managed to get the property value of a vault property attached to a folder in vault.
AddReference "Autodesk.Connectivity.WebServices.dll"
Imports AWS = Autodesk.Connectivity.WebServices
AddReference "Autodesk.DataManagement.Client.Framework.Vault.dll"
Imports VDF = Autodesk.DataManagement.Client.Framework
AddReference "Connectivity.Application.VaultBase.dll"
Imports VB = Connectivity.Application.VaultBase
AddVbFile "iLogic_Basis.vb"
Sub Main()
	Dim doc As Document = ThisDoc.Document
	'Vault Connection
	Dim mVltCon As VDF.Vault.Currency.Connections.Connection
	mVltCon = VB.ConnectionManager.Instance.Connection
	If  mVltCon Is Nothing Then
	     MsgBox("Not logged into Vault",,"Error" )
	     Exit Sub
	End If
	'insert the property name as string
	vault_get_folder_prop(doc.FullFileName, mVltCon, "yourPropertyName")
End Sub
Function vault_get_folder_prop(filepath As String, vaultconnection As VDF.Vault.Currency.Connections.Connection, propname As String) As String
	'complete the path to your local vault working directory
	filepath = filepath.Replace("C:\XX\", "$/")
	'flip the slashes
	filepath = filepath.Replace("\", "/")
	Dim VaultPaths() As String = New String() {filepath}
	Dim wsFiles() As AWS.File = vaultconnection.WebServiceManager.DocumentService.FindLatestFilesByPaths(VaultPaths)
	Dim mFileIt As AWS.File = New VDF.Vault.Currency.Entities.FileIteration(conn, wsFiles(0))
	'get the folder ID of the folder your currently opened Inventor file is located in
	Dim folderid As Long = mFileIt.FolderId
	'get the property definition ID of your desired property
	Dim pdefs() As AWS.PropDef = vaultconnection.WebServiceManager.PropertyService.GetPropertyDefinitionsByEntityClassId("FLDR")
	Dim propdef_ID As Long
	For Each propdef In pdefs
		If propdef.DispName = propname Then
			propdef_ID = propdef.Id
		End If
	Next
	'get the property value of your desired property
	Dim propValues As AWS.PropInst() = vaultconnection.WebServiceManager.PropertyService.GetProperties("FLDR", New Long(){folderid},New Long(){propdef_ID})
	Dim propValue As String = DirectCast(propValues(0).Val, String)
	Return propValue
End Function
