Event after a file has completely opened
12 REPLIES 12
Message 1 of 13
NachitoMax
874 Views, 12 Replies
Hi
I need to run a method after a drawing has completely opened. When a drawing opens, it takes a little bit of time to load the requirements, then you see the page appear and then finally, everything loads. (this can vary per drawing). Is there a method that gets called when the drawing has completely opened?
Nacho
Nacho
Automation & Design Engineer
Inventor Programmer (C#, VB.Net / iLogic)
12 REPLIES 12
Message 2 of 13
What do you mean with completely opened?
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Message 3 of 13
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2015...
Run the "After Open" event trigger and add in a timed delay?
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 4 of 13
How long should this delay be defined.
Better is to know what your criteria is regarding the completely opened definition.
Like:
All views up to date.
Etcetera
Arthur Knoors
Message 5 of 13
NachitoMax
in reply to: NachitoMax
Hi
I'm actually only opening a blank template everytime. I have a function I need to call but the template must be completely open before it fires otherwise it doesn't work.
Cheers
Nacho
Message 6 of 13
NachitoMax
I coouldnt seem to find any code samples showing how to invoke the after open event. How do I call it when the drawing opens and where to I place the code? Is there a drawingopen event?
I'm not doing this in ilogic, it's in vb.net
Cheers
Nacho
Nacho
Message 7 of 13
You need to use the applicationevent, on document open event.
Arthur Knoors
Message 8 of 13
http://jprdintprev.autodesk.com/adn/servlet/devnote?siteID=4814862&id=5790168&linkID=4900577
Arthur Knoors
Message 9 of 13
Any questions left?
Arthur Knoors
Message 10 of 13
NachitoMax
Hi
Sorry, been well busy this past week..
I did a sample using the ApplicationEvent on document open bit it didn't seem to fire. I also set up a document change event with a simple msgbox("changed") to see if that worked and it didnt..
I'm not using illogic, currently testing in VBA and my tool will be in .net.
I'll look for some examples 🙂
Appreciate it
Nacho
Nacho
Message 11 of 13
I can send you an example. It is not that complicated.
Arthur Knoors
Message 12 of 13
Hi
would you mind posting an example if you have the time? My code looks right but nothing happens at all. No errors, no function
Cheers
Nacho
Message 13 of 13
Please find the Application Add In event:
Imports Inventor
Imports System.Runtime.InteropServices
Imports Microsoft.Win32
Namespace InventorAddIn2
    <ProgIdAttribute("InventorAddIn2.StandardAddInServer"), _
    GuidAttribute("78ee7c88-8b32-4af9-801b-3d2925c7b66c")> _
    Public Class StandardAddInServer
        Implements Inventor.ApplicationAddInServer
        ' Inventor application object.
        Private m_inventorApplication As Inventor.Application
        Private m_ClientID As String
        'Application events
        Private WithEvents m_inventorApplicationEvents As ApplicationEvents
#Region "ApplicationAddInServer Members"
        Public ReadOnly Property InventorApplication As Inventor.Application
            Get
                Return m_inventorApplication
            End Get
        End Property
        Public Sub Activate(ByVal addInSiteObject As Inventor.ApplicationAddInSite, ByVal firstTime As Boolean) Implements Inventor.ApplicationAddInServer.Activate
            ' This method is called by Inventor when it loads the AddIn.
            ' The AddInSiteObject provides access to the Inventor Application object.
            ' The FirstTime flag indicates if the AddIn is loaded for the first time.
            ' Initialize AddIn members.
            m_inventorApplication = addInSiteObject.Application
            m_ClientID = AddInGuid(GetType(StandardAddInServer))
            m_inventorApplicationEvents = m_inventorApplication.ApplicationEvents
            ' TODO:  Add ApplicationAddInServer.Activate implementation.
            ' e.g. event initialization, command creation etc.
            SetupUserInterface(addInSiteObject, firstTime, m_ClientID)
        End Sub
        Public Sub Deactivate() Implements Inventor.ApplicationAddInServer.Deactivate
            ' This method is called by Inventor when the AddIn is unloaded.
            ' The AddIn will be unloaded either manually by the user or
            ' when the Inventor session is terminated.
            ' TODO:  Add ApplicationAddInServer.Deactivate implementation
            ' Release objects.
            Marshal.ReleaseComObject(m_inventorApplication)
            m_inventorApplication = Nothing
            System.GC.WaitForPendingFinalizers()
            System.GC.Collect()
        End Sub
        Public ReadOnly Property Automation() As Object Implements Inventor.ApplicationAddInServer.Automation
            ' This property is provided to allow the AddIn to expose an API
            ' of its own to other programs. Typically, this  would be done by
            ' implementing the AddIn's API interface in a class and returning
            ' that class object through this property.
            Get
                Return Nothing
            End Get
        End Property
        Public Sub ExecuteCommand(ByVal commandID As Integer) Implements Inventor.ApplicationAddInServer.ExecuteCommand
            ' Note:this method is now obsolete, you should use the
            ' ControlDefinition functionality for implementing commands.
        End Sub
#End Region
        Public Shared ReadOnly Property AddInGuid(ByVal t As Type) As String
            Get
                Dim guid As String = ""
                Try
                    Dim customAttributes() As Object = t.GetCustomAttributes(GetType(GuidAttribute), False)
                    Dim guidAttribute As GuidAttribute = CType(customAttributes(0), GuidAttribute)
                    guid = "{" + guidAttribute.Value.ToString() + "}"
                Finally
                    AddInGuid = guid
                End Try
            End Get
        End Property
        Public Sub SetupUserInterface(ByVal addInSiteObject As Inventor.ApplicationAddInSite, ByVal firstTime As Boolean, ClientID As String)
        End Sub
        Private Sub m_inventorApplicationEvents_OnSaveDocument(DocumentObject As _Document, BeforeOrAfter As EventTimingEnum, Context As NameValueMap, ByRef HandlingCode As HandlingCodeEnum) Handles m_inventorApplicationEvents.OnSaveDocument
            If BeforeOrAfter = EventTimingEnum.kBefore Then
                MsgBox("before")
            End If
            If BeforeOrAfter = EventTimingEnum.kAfter Then
                MsgBox("after")
            End If
        End Sub
    End Class
End Namespace
Arthur Knoors
Technology Administrators
