I would like to be able to place a model in inventor and have a tool that automatically creates offset planes on every flat area with a default offset of zero. I was thinking that creating an add in would be best. Does anyone have any advice or code related to how I could achieve this? Any help is greatly appreciated.
Nathan
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Do you have any advice on how this add in would work? How could I use the API to automatically see faces and create these planes?
Could you share an example
Arthur Knoors
This will do the trick with i-logic:
Dim a As PartDocument = ThisDoc.Document Dim b As PartComponentDefinition = a.ComponentDefinition Dim c As SurfaceBody = b.SurfaceBodies.Item(1) Dim wpl As WorkPlane Dim f As Face For Each f In c.Faces If f.SurfaceType = 5890 Then Try wpl = b.WorkPlanes.AddByPlaneAndOffset(f,0) Catch End Try End If Next
Arthur Knoors
