Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Automated offset planes
4 REPLIES 4
NRHartness
160 Views, 4 Replies
     I would like to be able to place a model in inventor and have a tool that automatically creates offset planes on every flat area with a default offset of zero. I was thinking that creating an add in would be best. Does anyone have any advice or code related to how I could achieve this? Any help is greatly appreciated.
Nathan
4 REPLIES 4
I indeed prefer creating a add-in.
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
Do you have any advice on how this add in would work? How could I use the API to automatically see faces and create these planes?
Could you share an example
Arthur Knoors
This will do the trick with i-logic:
Dim a As PartDocument = ThisDoc.Document
Dim b As PartComponentDefinition = a.ComponentDefinition
Dim c As SurfaceBody = b.SurfaceBodies.Item(1)
Dim wpl As  WorkPlane
Dim f As Face
For Each f In c.Faces
	If f.SurfaceType = 5890 Then
		Try
		wpl = b.WorkPlanes.AddByPlaneAndOffset(f,0)
		Catch
		End Try
	End If
	Next
Arthur Knoors
