Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
AddVbFile problem
3 REPLIES 3
marcin_bargiel
330 Views, 3 Replies
AddVbFile problem
Some simplified rule :
header
AddVbFile "common_subs.vb"
Sub Main
ADD_PART(SOMETHING)
End Sub
in file common_subs.vb i've got many functions and rules, all work great expect that one :
simplified external rule :
header :
Imports Inventor
Class ThisRule
	Sub ADD_PART(ByVal PART As Double)
			Components.Add(CHILD_NAME, newAssembly, position := Nothing, grounded := False, visible := True, appearance := Nothing)
			Constraints.AddUcsToUcs("Flush_" & CHILD_NAME, CHILD_NAME, "UCS", PARENT_NAME, UCS_PARENT)
			iProperties.Value(CHILD_NAME, "Project", "Part Number") = Part_Number
	End Sub
End Class
 I've got those errors and I have no idea what to do with it. When Subroutine ADD_PART was previously in the original rule (not external connected by AddVbFile), it worked fine. :
Error on Line 281 : 'Constraints' is not declared. It may be inaccessible due to its protection level.
Error on Line 287 : 'iProperties' is not declared. It may be inaccessible due to its protection level.
Vote for REPLACE VARIES !
REPLACE VARIES
3 REPLIES 3
please upload your complete code so that we have all variable complete!
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
This happens because external VB file MUST contain only pure VB.NET code. You can't use iLogic shortcuts directly (like "iProperties",  "Components", etc.).
If you want to use them, you need to pass this objects to the external VB file as reference.
Local rule
AddVbFile "C:\Path\To\SetPartNumberExternal_iLogic.vb"
Dim extCode As New ExternalCode
'iProperties used below refers to the ThisDoc.Document properties.
extCode.SetPartNumber(iProperties)
Class ExternalCode
	Public Sub SetPartNumber(iProperties As IiProperties)
		iProperties.Value("Project", "Part Number") = "New PartNumber"
	End Sub
End Class
Or you need to use standard Inventor API. I prefer this approach, but it depends on your needs.
Local rule
AddVbFile "C:\Path\To\SetPartNumberExternal_API.vb"
extCode.SetPartNumber(ThisDoc.Document)
Class ExternalCode
	Public Sub SetPartNumber(doc As Inventor.Document)
        doc.PropertySets("{32853F0F-3444-11D1-9E93-0060B03C1CA6}")("Part Number").Value = "New PartNumber"
	End Sub
End Class
WCrihfield
in reply to: marcin_bargiel
Hi @marcin_bargiel.  It might help a little to know that there is a difference between the iLogic add-in's API (Link1, Link2) versus the main Inventor API.  Early on, when folks are attempting to automate things in Inventor through iLogic & VBA, it can be a bit confusing to separate them all out and tell which resource or term belongs to which code system.  There is a term used within the online help documentation called 'Rule Objects', which represents a bunch of variables that are declared and given values behind the scenes within every 'normal' iLogic rule we create, and are therefore readily available to us while we are working within most simpler codes in the iLogic Rule editor dialog.
Since these 'Rule Objects' are pretty much all some sort of Interface (Link1, Link2), instead of a Class (Link1, Link2, Link3), we can not simply create a new one using the 'New' keyword.  Due to how they are created for us, if we want to use them elsewhere (such as in externally referenced resources), we must 'pass' them to that other resource, one way or another, similar to what @Michael.Navara described above.  But it does not always need to be as an 'input' parameter to a method (Sub / Function routine).  If your external resource represents a custom Class, then that Class could have a Public Property containing both Get & Set functionality, then you could 'set' that property's value after creating a 'New' instance of that Class in your other rule.  Or you could have some sort of 'Initialize' type method defined within your Class, which when ran, asks for some of those 'Rule Objects' as inputs, then uses those to set the values of Private internal properties within the Class, that could then be used within all of its other internal tools.  There are lots of ways it could be done, but the main point is that the externally referenced Class will not recognize, or be able to use those 'Rule Objects' (because they were created elsewhere) until your 'regular rule' sends/passes them to it somehow.  But perhaps the more popular route would be to do everything in your referenced Class using Inventor API code, instead of using code that is unique to the iLogic add-in, then you would not need to send/pass anything like that to your externally referenced code.
Wesley Crihfield
(Not an Autodesk Employee)
