Cross Section Analysis Default settings?
Viktor.Lukjanow
Viktor.Lukjanow
Is there a way to set the default settings for cross-section analysis? i would like to set the wall thickness in the min and max fields and ideally also have the advance function active at the start.
daltonNYAW9
@Viktor.Lukjanow
I couldnt find anything on doing this with ilogic. However, you could create a rule that fills out the form with a series of tabs & arrow keys to mimic user input.
Ex.
ThisApplication.CommandManager.ControlDefinitions("AppCrossSectionAnalysisCmd").Execute
System.Windows.Forms.SendKeys.SendWait("{LEFT}")
System.Windows.Forms.SendKeys.SendWait("{TAB}" & "{TAB}" & "{TAB}" & "{TAB}")
System.Windows.Forms.SendKeys.SendWait("{UP}")
System.Windows.Forms.SendKeys.SendWait("{TAB}" & "{TAB}")
System.Windows.Forms.SendKeys.SendWait("1 in")
System.Windows.Forms.SendKeys.SendWait("{TAB}")
System.Windows.Forms.SendKeys.SendWait("2 in")
 If you save this rule as an external rule you can add it to the "Inspect" panel next to the default Section command.
Viktor.Lukjanow
THX DaltonNYAW9. This is a good solution for me.
