Windows explorer crashes After Installation Inventor 2026
bradeneuropeArthur
Mentor Mentor
Message 1 of 14
bradeneuropeArthur
Anybody familiar with the situation that windows explorer crashes opening the D partition on windows 11?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Replies (13)
Message 2 of 14
bradeneuropeArthur
Solved by step by step removing file from the drive selves, with another portable file explorer (total Commander).
One of the files was corrupted.
After remove everything works again.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 3 of 14
bradeneuropeArthur
To may findings it could be Inventor related. When I have Inventor 2026 open the D drive partition crashes again.
Is there maybe a corruption created on D by inventor?
I have all my data on this D drive including the Inventor projects and file/settings like CC and design data.
@CGBenner @johnsonshiue @ChrisMitchell01 @dan_szymanski Could you and your team have a closer look at this issue?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 4 of 14
bradeneuropeArthur
I have tested and indeed files that I create with Inventor 2026 make the folder in corrupted and Explorer Crashes.
After remove the files with Total Commander it is good again.
Please let me know if and what to do or what your team can do.
I cannot even share the files because when selected explorer crashes.....
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 14
bradeneuropeArthur
I have found that indeed Inventor is the issue.
seems that it has to do with the prompt shown when hover the inventor files in Inventor.
this was before the trick here below not shown and crashed Win Explorer.
I hope that I have it solved now with the default app settings which was for me on Inventor 2023 and not on the later installed 2025 or 2026 edition.
Maybe there lays the issue with more then one version installed of Inventor.
Still I am not able to change dwg extension to Inventor 2025 or 2026. therefor I have now chosen dwg launcher.
Hope that we are coming closer?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 6 of 14
bradeneuropeArthur
Maybe relevant these old same issues with crashes of file explorer.
<span;>https://forums.autodesk.com/t5/inventor-forum/inventor-crashes-explorer/td-p/5820945
<span;><span;>https://forums.autodesk.com/t5/inventor-forum/inventor-2018-causing-windows-file-explorer-crash-win7...</span;></span;></span;>
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 14
MartinPapez
Hi @bradeneuropeArthur,
You are not alone. After installing Inventor 2026, my system started freezing and crashing. When I hover over the icon, the prompts appear,
but clicking it causes the computer to freeze. So I am not sure, the proms are the problem. Shortly after, Windows Explorer crashes.
I took picture with phone.
Everything works fine when I uninstall Inventor 2026 and revert to 2025. Windows and drivers are fully updated.
Message 8 of 14
MartinPapez
Update: Even with Inventor 2026 instaled, when the default app is Inventor 2025, Windows Explorer wokrs without isue.
Message 9 of 14
MartinPapez
I foud out, that I do not have the isue with I.2026, when the preview is switched off. With Inventor 2025 works the preview ok.
Message 10 of 14
bradeneuropeArthur
For me also after unisntall of Inventor 2026 the system Win Explorer keeps crashing. I have the dwg file associated with Autocad dwg launcher, not to Inventor 2025 or 2026.
Hope that Autodesk comes soon and quick with a update for this!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 11 of 14
ChrisMitchell01
Hi Arthur,
We haven't heard of this before other than the forum topics you've referenced. Do you have an explorer.exe.12345.dmp files in
Chris Mitchell
PDMS Customer Engagment Team
Autodesk, Inc.
Message 12 of 14
mdavis22569
@ChrisMitchell01
I'm seeing tickets for both Inventor and AutoCAD 2026 doing this ..
Mike Davis
Message 13 of 14
ChrisMitchell01
Ok - can you provide any explorer crash dumps as mentioned below, please?
-Chris
Chris Mitchell
Autodesk, Inc.
Message 14 of 14
mdavis22569
last one was AutoCAD .. I'll watch for the Inventor to share
Mike Davis
