Not sure if this is what you are looking for but in 2021 I wrote a blog post about creating a loft feature. You can find it here: Best Wishes & A Loft Feature
This is the part of the code that you want to have a look at. (It will produce something like this.)
Public Class ThisRule
' Code written by: Jelte de Jong
' www.hjalte.nl
Private Sub createLoft()
' find 2 faces for the loft
Dim objColl As ObjectCollection
Try
objColl = ThisApplication.TransientObjects.CreateObjectCollection()
For Each face As Face In def.SurfaceBodies.Item(1).Faces
If (Face.GeometryForm = 9) Then
If (DoubleForEquals.IsEqual( Face.Evaluator.Area, 100)) Then
Dim s As PlanarSketch = def.Sketches.Add(Face, True)
Dim p As Profile = s.Profiles.AddForSolid()
objColl.Add(p)
Next
Catch ex As Exception
MsgBox("Exception was thrown while searching for faces")
Return
End Try
If (objColl.Count <> 2) Then
Throw New Exception("Did not find the 2 faces for creating the Loft")
' create a LoftDefinition object
Dim loftDef As LoftDefinition = def.Features.LoftFeatures.CreateLoftDefinition(objColl, PartFeatureOperationEnum.kJoinOperation)
Try
' create an object for the mapping of the points
Dim curves As MapPointCurves = def.Features.LoftFeatures.CreateMapCurves(objColl)
' create a curve and and give posistion of start and end point
Dim curve1 = curves.AddMapCurve()
curve1.SetPositionUsingPoint(2, oTg.CreatePoint(0, 0, 0))
curve1.SetPositionUsingPoint(1, oTg.CreatePoint(10, 20, 0))
Dim curve2 = curves.AddMapCurve()
curve2.SetPositionUsingPoint(2, oTg.CreatePoint(10, 0, 0))
curve2.SetPositionUsingPoint(1, oTg.CreatePoint(10, 20, -10))
Dim curve3 = curves.AddMapCurve()
curve3.SetPositionUsingPoint(2, oTg.CreatePoint(10, 0, -10))
curve3.SetPositionUsingPoint(1, oTg.CreatePoint(0, 20, -10))
Dim curve4 = curves.AddMapCurve()
curve4.SetPositionUsingPoint(2, oTg.CreatePoint(0, 0, -10))
curve4.SetPositionUsingPoint(1, oTg.CreatePoint(0, 20, 0))
loftDef.MapPointCurves = curves
MsgBox("Unable to create transitions")
End Try
Dim loftFeature As LoftFeature = def.Features.LoftFeatures.Add(loftDef)
End Sub
Private lastPoint2D As SketchPoint
Private currentSketch As PlanarSketch
Private oTg As TransientGeometry
Private def As PartComponentDefinition
Private doc As PartDocument
Private view As Inventor.View
Sub Main()
oTg = ThisApplication.TransientGeometry
doc = ThisApplication.Documents.Add(DocumentTypeEnum.kPartDocumentObject)
def = doc.ComponentDefinition
view = ThisApplication.ActiveView
Dim oAssets As Assets = doc.Assets
Dim assetOrrange As Asset = doc.ActiveAppearance
Dim generic_color As ColorAssetValue = assetOrrange.Item("generic_diffuse")
generic_color.Value = ThisApplication.TransientObjects.CreateColor(236, 164, 74)
generic_color.HasConnectedTexture = True
Dim trans As Transaction = ThisApplication.TransactionManager.StartTransaction(doc, "create")
Try
Dim wp1 As WorkPlane = createWorkplane(oTg.CreatePoint(0, 0, 0), oTg.CreatePoint(1, 0, 0), oTg.CreatePoint(0, 1, 0))
drawLogo(doc, wp1)
createLoft()
view.Fit()
Dim camera As Camera = ThisApplication.ActiveView.Camera
camera.Perspective = True
camera.Eye = oTg.CreatePoint(-8.9, 90.7, 169.9)
camera.Target = oTg.CreatePoint(39.2, -3.7, -5)
camera.UpVector = oTg.CreateUnitVector(0.126, 0.887, -0.444)
camera.Animating = True
camera.Apply()
view.Fit()
MsgBox(ex.Message)
Finally
trans.End()
End Try
End Sub
Private Function createWorkplane(point1 As Point, point2 As Point, point3 As Point)
Dim p1 = def.WorkPoints.AddFixed(point1)
Dim p2 = def.WorkPoints.AddFixed(point2)
Dim p3 = def.WorkPoints.AddFixed(point3)
Dim wp As WorkPlane = def.WorkPlanes.AddByThreePoints(p1, p2, p3)
p1.Visible = False
p2.Visible = False
p3.Visible = False
wp.Visible = False
Return wp
End Function
Private Sub drawLogo(doc As PartDocument, wp1 As WorkPlane)
Try
currentSketch = def.Sketches.Add(wp1)
lastPoint2D = currentSketch.SketchPoints.Add(oTg.CreatePoint2d(0, 0))
Dim startPoint As SketchPoint = lastPoint2D
Dim ls = arcTo(oTg.CreatePoint2d(-2, 0), oTg.CreatePoint2d(-2, -2))
lineTo(oTg.CreatePoint2d(-5, -2))
lineTo(oTg.CreatePoint2d(-5, -6))
arcTo(oTg.CreatePoint2d(5, -86), oTg.CreatePoint2d(15, -6))
lineTo(oTg.CreatePoint2d(15, -2))
lineTo(oTg.CreatePoint2d(12, -2))
arcTo(oTg.CreatePoint2d(12, 0), oTg.CreatePoint2d(10, 0))
lineTo(startPoint)
view.Fit()
lastPoint2D = currentSketch.SketchPoints.Add(oTg.CreatePoint2d(0, 20))
startPoint = lastPoint2D
arcTo(oTg.CreatePoint2d(-2, 20), oTg.CreatePoint2d(-2, 22), True)
lineTo(oTg.CreatePoint2d(-5, 22))
lineTo(oTg.CreatePoint2d(-5, 26))
arcTo(oTg.CreatePoint2d(5, 106), oTg.CreatePoint2d(15, 26), True)
lineTo(oTg.CreatePoint2d(15, 22))
lineTo(oTg.CreatePoint2d(12, 22))
arcTo(oTg.CreatePoint2d(12, 20), oTg.CreatePoint2d(10, 20), True)
lineTo(startPoint)
view.Fit()
Dim oProfile As Profile = currentSketch.Profiles.AddForSolid()
Dim oExtrudeDef As ExtrudeDefinition = def.Features.ExtrudeFeatures.CreateExtrudeDefinition(oProfile, PartFeatureOperationEnum.kJoinOperation)
Call oExtrudeDef.SetDistanceExtent(10, PartFeatureExtentDirectionEnum.kNegativeExtentDirection)
Dim oExtrude As ExtrudeFeature = def.Features.ExtrudeFeatures.Add(oExtrudeDef)
Catch
MsgBox("Exception was thrown while creating logo")
End Try
End Sub
Private Function arcTo(centerPoint As Point2d, EndPoint As Point2d, Optional CounterClockwise As Boolean = False)
Dim l = currentSketch.SketchArcs.AddByCenterStartEndPoint(centerPoint, lastPoint2D, EndPoint, CounterClockwise)
If (CounterClockwise) Then
lastPoint2D = l.EndSketchPoint
Else
lastPoint2D = l.StartSketchPoint
Return l
End Function
Private Function lineTo(EndPoint)
Dim l As SketchLine = currentSketch.SketchLines.AddByTwoPoints(lastPoint2D, EndPoint)
Return l
End Function
End Class
Jelte de Jong
Blog: hjalte.nl - github.com
