Is it possible to use the inventory api to determine the entity name for the corner used in the assembly constraint??
seosk1571C4FHH
seosk1571C4FHH
a.brusamolino
Hi!
If by "corner" you mean a vertex or an edge that you have selected to set the constraint, then yes, it’s possible!
You just need to access the "EntityOne" or "EntityTwo" fields of that particolar constraint contained in the constraints list of AssemblyComponentDefinition.
oDoc.ComponentDefinition.Constraints.Item(i).EntityOne
seosk1571C4FHH
Thank you for your answer.
Can't I get a name like edge_A shown in the picture?
a.brusamolino
Yes you can! Once you define the entity you want (e.g. oEdge), you can get the desired Assigned Name in this way:
EntityAttributeSet = oEdge.AttributeSets("iLogicEntityNameSet")
EntityName = EntityAttributeSet.Item("iLogicEntityName").Value
MsgBox(EntityName)
Hope it helps!
seosk1571C4FHH
Thank you so much.
My problem has been solved perfectly
