Write BOM QTY to part files, but skipping Library files
So, my lack of iLogic knowledge is fully apparent with this one.
We are currently using this code to write all the quantities to part level in a Custom iProperty, including how many pieces are not in a subassembly.
However, know I would like to edit this so it skips all the non-editable parts, thinking about Library parts and later parts that are set to Released in Vault.
Can anyone help me?
Thanks in advance!
doc = ThisDoc.Document
Dim oAssyDef As AssemblyComponentDefinition = doc.ComponentDefinition
Dim oBOM As BOM = oAssyDef.BOM
oBOM.PartsOnlyViewEnabled = True
Dim oBOMView As BOMView = oBOM.BOMViews.Item("Structured")
Dim oBOMRow As BOMRow
question = MessageBox.Show("Write Assemblyname and Quantities to Parts", "Actum-Services",MessageBoxButtons.YesNo,MessageBoxIcon.Question)
If question = vbYes Then
Dim oBOMView3 As BOMView = oBOM.BOMViews.Item("Parts Only")
Dim oBOMRow3 As BOMRow
For Each oBOMRow3 In oBOMView3.BOMRows
'Set a reference to the primary ComponentDefinition of the row
Dim oCompDef As ComponentDefinition
oCompDef = oBOMRow3.ComponentDefinitions.Item(1)
Dim CompFullDocumentName As String = oCompDef.Document.FullDocumentName
Dim CompFileNameOnly As String
Dim index As Integer = CompFullDocumentName.LastIndexOf("\")
CompFileNameOnly = CompFullDocumentName.Substring(index+1)
Dim Qty As String
Qty = oBOMRow3.TotalQuantity
iProperties.Value(CompFileNameOnly, "Custom", "LoosePieces") = 0
Next
For Each oBOMRow In oBOMView.BOMRows
oCompDef = oBOMRow.ComponentDefinitions.Item(1)
Dim Qty As String
Qty = oBOMRow.TotalQuantity
iProperties.Value(CompFileNameOnly, "Custom", "LoosePieces") = Qty
iProperties.Value(CompFileNameOnly, "Custom", "PCS") = Qty
iProperties.Value(CompFileNameOnly, "Custom", "Assemblyname") = ThisDoc.FileName(False)
Next
Dim oBOMView2 As BOMView = oBOM.BOMViews.Item("Parts Only")
Dim oBOMRow2 As BOMRow
For Each oBOMRow2 In oBOMView2.BOMRows
oCompDef = oBOMRow2.ComponentDefinitions.Item(1)
Dim AllPieces As String
AllPieces = oBOMRow2.TotalQuantity
iProperties.Value(CompFileNameOnly, "Custom", "PCS") = AllPieces
Next
