Write BOM QTY to part files, but skipping Library files
nick_desmet3CLTQ
Observer Observer
nick_desmet3CLTQ
Observer
Observer
So, my lack of iLogic knowledge is fully apparent with this one.
We are currently using this code to write all the quantities to part level in a Custom iProperty, including how many pieces are not in a subassembly.
However, know I would like to edit this so it skips all the non-editable parts, thinking about Library parts and later parts that are set to Released in Vault.
Can anyone help me?
Thanks in advance!
doc = ThisDoc.Document
Dim oAssyDef As AssemblyComponentDefinition = doc.ComponentDefinition
Dim oBOM As BOM = oAssyDef.BOM
oBOM.PartsOnlyViewEnabled = True
Dim oBOMView As BOMView = oBOM.BOMViews.Item("Structured")
Dim oBOMRow As BOMRow
question = MessageBox.Show("Write Assemblyname and Quantities to Parts", "Actum-Services",MessageBoxButtons.YesNo,MessageBoxIcon.Question)
If question = vbYes Then
Dim oBOMView3 As BOMView = oBOM.BOMViews.Item("Parts Only")
Dim oBOMRow3 As BOMRow
For Each oBOMRow3 In oBOMView3.BOMRows
    'Set a reference to the primary ComponentDefinition of the row
    Dim oCompDef As ComponentDefinition
    oCompDef = oBOMRow3.ComponentDefinitions.Item(1)
    Dim CompFullDocumentName As String = oCompDef.Document.FullDocumentName
    Dim CompFileNameOnly As String
    Dim index As Integer = CompFullDocumentName.LastIndexOf("\")
    CompFileNameOnly = CompFullDocumentName.Substring(index+1)
    Dim Qty As String
    Qty = oBOMRow3.TotalQuantity
    iProperties.Value(CompFileNameOnly, "Custom", "LoosePieces") = 0
Next
For Each oBOMRow In oBOMView.BOMRows
    oCompDef = oBOMRow.ComponentDefinitions.Item(1)
    Dim Qty As String
    Qty = oBOMRow.TotalQuantity
    iProperties.Value(CompFileNameOnly, "Custom", "LoosePieces") = Qty
	iProperties.Value(CompFileNameOnly, "Custom", "PCS") = Qty
	iProperties.Value(CompFileNameOnly, "Custom", "Assemblyname") = ThisDoc.FileName(False)
Next
Dim oBOMView2 As BOMView = oBOM.BOMViews.Item("Parts Only")
Dim oBOMRow2 As BOMRow
For Each oBOMRow2 In oBOMView2.BOMRows
    oCompDef = oBOMRow2.ComponentDefinitions.Item(1)
Dim AllPieces As String
    AllPieces = oBOMRow2.TotalQuantity
    iProperties.Value(CompFileNameOnly, "Custom", "PCS") = AllPieces
Next
End If
bradeneuropeArthur
Try this out please.
I have added this:
	Dim p As Document = oCompDef.Document
	If p.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
		Dim prt As PartDocument = p
		If prt.ComponentDefinition.IsContentMember Then
	Exit For
	End If
	End If
With this as result
	Exit For
	End If
	End If
    Dim Qty As String
Next
	Exit For
	End If
	End If
    Dim Qty As String
Next
	Exit For
	End If
	End If
Next
End If
 Knowing/using this the code could be much simpler, but that was not the question isn't it?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
