Why are there two versions of each style? spaces in ANSI styles vs not
Hunteil
Message 1 of 13
Hunteil
I don't understand what this is from... But on a fresh install. Brand new template, I have two versions of what looks to be the same thing... All the way down to the layers having 2 versions.
Example: (also see attached)
"Object Defaults (ANSI)"
"ObjectDefaults(ANSI)"
(name differences are with spaces and versions without spaces)
Layer: "Work Point (ANSI)"
Layer: "Work Point(ANSI)"
etc etc etc...there's a lot of these similar things...
On the layer side... The difference seems to be color instead of black, being a dark dark blue ish purple and scale by line weight I think...
Anyways my question is... what is this? why is there 2 versions? Is this Autodesk accidentally leaving in an old copy by accident? Or does it have a purpose? (It's confusing as heck)
My version is  Inventor 2019 I think the version before 2019.4.4... (can't find the help>about product button)
Inventor: Model States is not a replacement for iParts / iAssemblies. It does not have all the same features yet and does not communicate well with our large currently in use libraries. 😞 https://forums.autodesk.com/t5/inventor-ideas/model-state-support-tabulated-parts-list/idc-p/11360616
Replies (12)
Message 2 of 13
bradeneuropeArthur
These are not completely the same since the displayname is different!
Maybe you could take a look if the list is only Local or Library styles
Seems that the local styles have been edit and there is a diffrence.
You could take a closer look with the LibraryTools in the inventor sofwere folder.
Herewith you can compare what the difference is.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 13
Hunteil
Using the Style Library Manager. I don't see them.
Plus I worked on it and deleted them so they wouldn't confuse my co-workers.... But it sounds like you're saying that these styles are not pre-installed with inventor... am I correct?
Message 4 of 13
bradeneuropeArthur
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 13
bradeneuropeArthur
Also take a look if this are local styles?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 6 of 13
Hunteil
I think they are local and made locally now...
Message 7 of 13
Hunteil
Ignore my OP question... I already cleaned up the mess mostly.
Again I'm now assuming it's old from someone else putting it in.
I do have a question though... In the Autodesk Inventor Style Library Manager...
I can see the style I made for our department... But... There's all these extra styles that don't show up in my template.idw document... Can I safely delete those?
Message 8 of 13
bradeneuropeArthur
These are not migrated styles!
If you can delete depends on your needs.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 9 of 13
Hunteil
What does that mean?
(sorry for the newbie questions. But I don't want to assume the wrong thing.)
Message 10 of 13
bradeneuropeArthur
Have you switched/upgraded to a newer version of inventor lately?
Then you need to update also the libraries to the newer version of inventor.
This is called migrate.
This comes from the help file:
Comparing Styles Between Definitions
If a style exists in both Style Libraries and is an exact name value match (that is, Equal), then the text in the style lists has a normal font display.
If a style exists in both Style Libraries, is an exact name match, and is not a value match (that is, Not Equal), then the text for this style name displays as bold, underlined, and red.
If a style only exists in one Style Library (that is, is Unique), then the text for this style name displays as bold, underline, and blue.
Is this the case for you?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 11 of 13
bradeneuropeArthur
Take also a look at this:
http://help.autodesk.com/view/INVNTOR/2018/ENU/?guid=GUID-C71EFF99-2DCD-4E8F-B3EC-215592571B9A
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 12 of 13
Hunteil
The red items were not red items before. I think that happen b/c I deleted them in my Styles.
Technically everything below the CCS Style Library (blue file) is all stuff I don't need or want for my drafters.
What I don't understand is why are they even listed? My template.idw doesn't even list them. I've use the save style button. But the styles still exist in the manager.
Message 13 of 13
bradeneuropeArthur
You need to purge them from the library, if possible.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
