ilogic to open engineers notes
tom_rafferty1234
tom_rafferty1234
Is there a way to use ilogic to open the engineers notebook?
I have added a custom user guide to one of our more complex models, currently embedded into the engineers notes section in the master part.  Ideally I'd like to add a button to the main form called "User Guide", and when you click this button it opens up the engineers notebook, displaying the user guide.
I'm aware I could use ilogic to open an external file, but I don't really want to link to an external file (if possible).
bradeneuropeArthur
Why not referring to an embedded file?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
tom_rafferty1234
As long as the file is embedded (and not an external file) then this would be ok. How can I embed a .docx file into an .ipt?
tom_rafferty1234
I have resolved this using an embedded file as suggested.
Used Manage, Insert Object to embed a word document.
Code to run the userguide:
Imports Inventor.OLEDocumentTypeEnum
WordApp = CreateObject("Word.Application")
Dim WordFile As ReferencedOLEFileDescriptor
WordFile = ThisDoc.Document.ReferencedOLEFileDescriptors.Item(1)
WordFile.Activate(kEditOpenOLEVerb, WordApp)
bradeneuropeArthur
Dim objDocument As DrawingDocument
    Set objDocument = ThisApplication.ActiveDocument
    Dim objReferenceOLE As ReferencedOLEFileDescriptor
                Set objReferenceOLE = objDocument.ReferencedOLEFileDescriptors.Add("Your path")
End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
bradeneuropeArthur
And this to open:
Sub OpenEmbeddedfile()
Dim oApp As Inventor.Application
Set oApp = ThisApplication
Dim oOleRef As ReferencedOLEFileDescriptor
Set oOleRef = oApp.ActiveDocument.ReferencedOLEFileDescriptors.Item(1)
Dim owb As Object
Call oOleRef.Activate(kEditOpenOLEVerb, owb)
End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
