VBA macro to set an assembly BOM Structure Purchased
Claudio_73
Message 1 of 13
Claudio_73
Hi, how can i create a VBA macro to set an assembly BOM Structure to Purchased?
Thx
I try but it doesn't work
Sub Purchased()
Dim oAsmDoc As AssemblyDocument
Set oAsmDoc = ThisApplication.ActiveDocument
Dim oAsmDef As AssemblyComponentDefinition
Set oAsmDef = oAsmDoc.ComponentDefinition
'Dim AssemblyComponentDefinition.BOMStructure() As BOMStructureEnum
'Set AssemblyComponentDefinition.BOMStructure = kPurchasedBOMStructure
Dim oBomStr As BOMStructureEnum
Set oBomStr.Value = kPhantomBOMStructure
'Set oBomEnum = oBomstr.
'Dim oBomStr As BOMStructure
'Set oBomStr = oBom.
'Dim BOMStructure As BOMStructureEnum
'Set BOMStructure = BOMStructureEnum.kPhantomBOMStructure
End Sub
Replies (12)
Message 2 of 13
MechMachineMan
Sub Purchased()
Set oAsmDef.BOMStructure = kPurchasedBOMStructure
End Sub
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 3 of 13
Claudio_73
I tried, but doesn't work. See image attached.
Thanks.
Message 4 of 13
bradeneuropeArthur
Remove the last "set":
Sub Purchased()
End Sub
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 5 of 13
Claudio_73
I tried, but doesn't work. See image attached. Thanks2017-12-06 22_53_46-Microsoft Visual Basic for Applications - Default.ivb [running] - [Purchased (Co.png
Message 6 of 13
bradeneuropeArthur
Sub Purchased()
    MsgBox oAsmDef.BOMStructure
    oAsmDef.BOMStructure = 51973 'kPurchasedBOMStructure
End Sub
 Try the above.
is the msgbox representing anything?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 13
Claudio_73
Now it works, but why does it need a number?
Message 8 of 13
bradeneuropeArthur
Solved?
or better use this coding to be sure that you referencing to  the right document.
Sub Purchased()
    Set oAsmDoc = ThisDocument 'ThisApplication.ActiveDocument
End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 9 of 13
bradeneuropeArthur
I think the problem was the active document.
this was not the assembly.
both should work it think.
Sometimes the number is needed.
but as I understood only for illogic rules it is necessary sometimes.
Please  mark as solved for administrative reasons, but also for MechMachineMan he only forgot to remove the last "set".
MechMachineMan provided the rest of coding, to be honest......
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 10 of 13
Claudio_73
Ok. Thanks a lot.
Regars
Message 11 of 13
MechMachineMan
You get the points for being correct/testing it though Smiley Wink
It's what I get for half-a**ing it haha Smiley Sad
Justin K
Message 12 of 13
bradeneuropeArthur
We all know that the intention was correct.
So there should be a solution solved also for you I think?
But only the initiator can do that.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 13 of 13
MechMachineMan
Expert Elites and mods can as well, but i don't like to abuse the privilege, and I'm not to concerned about it anyways.
Justin K
