vba Macro Button acting weird
sam
sam
Hi guys,
hoping everyone is safe. I had setup macro button with help of you generous people. Took guidance from these two posts.
https://forums.autodesk.com/t5/inventor-customization/vba-forms-how-do-i-distribute/m-p/9600908#M112...
https://forums.autodesk.com/t5/inventor-customization/no-customicon-to-vba-macro-button/td-p/9061649
It was working properly for sometimes, since my work was in progress and as I added more pages to my form and more modules something really strange started to happen. So when I run macro from button first page (of multi-page) works just fine but second page of form is not working/loaded properly (it gives error). But if I run same from within VBA it works properly on all pages.
Any idea why this is happening? is it because when I call form through macro only code within that form is recognized but code that is accessed from other modules is not working?? really lost here.
Best regards,
sam
bradeneuropeArthur
Could you upload the code here?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
sam
@bradeneuropeArthur Thanks for your answer and sorry I couldn't reply sooner.
Unfortunately I can't upload my file and code (against work policy) but I tried to figure it out and I think I (might) have found the reason. The code that was categorised in modules but was referenced buy code in form was causing the stated problem. so when I copied code back from these modules to form code everything seems to work fine now. thanks again for your reply though.
