Changing Unit type from cm to mm using VB
Hi All,
Looking for some help, when I shrinkwrap out a drawing using the API, the return IPT is in cm when I need it in mm. I don't particularly want to use Ilogic as this is all controlled though VB. I believe I should be using "UnitsTypeEnum.kMillimeterLengthUnits" I just can't work out how it has be be written correctly.
Below is a small snippet of where it will sit (I believe).
Thanks again for the help
            ShRDef.RemoveInternalParts = False
            ShRDef.RemovePartsBySize = False
            'ShRDef.RemovePartsSize = 5 'cm
            '''''''''''''''''''''''''''''''ShRDef.RemovePocketsMaxFaceLoopRange = 10 'cm
            ShRDef.RemovePocketsStyle = ShrinkwrapRemoveStyleEnum.kShrinkwrapRemoveByRange
            ShRDef.RenameComponent = True
            ShRDef.UseColorOverrideFromSourceComponent = True
            ShrComp = oPCD.ReferenceComponents.ShrinkwrapComponents.Add(ShRDef)
            <<<< Change Unit Type would sit here>>>
            'Save Documents and create DWG
            Dim activeDoc As Inventor.PartDocument
            activeDoc = _invApp.ActiveEditObject
            activeDoc.SaveAs(fileNameIPTS, True)
            activeDoc.SaveAs(fileNameShrink, True)
            activeDoc.Close(True)
            oDoc.Close(True)
JhoelForshav
Hi @Anonymous
Since you have only included a small portion of your code it's a bit difficult to follow...
Is activeDoc the document you save as a dwg? if you look at the document settings for that document, is it set to centimeters? If so maybe it helps to just change that setting before saving the document?
activeDoc.UnitsOfMeasure.LengthUnits = UnitsTypeEnum.kMillimeterLengthUnits
Thankyou 🙂
