Rename a set of work features through Ilogic
mat_hijs
mat_hijs
I'm looking for a way to rename a selected set of work features through Ilogic. For example:
I'll make a part with 8 vertical work axis, and 3 horizontal work axis.
I want to name the vertical work axis "As_Stijl_*" and the horizontal work axis "As_Regel_*". * being the numbers from 1-8 and 1-3.
I found this bit of code, which renames all work axis in the part. I think it shouldn't be too hard to make something where you'd select a set of work features and rename only the selected set. But I have no idea how to start this. Can anyone help me out?
'Rename work axis
oDoc = ThisApplication.activedocument
i = 1
For Each oWorkAxis In oDoc.ComponentDefinition.WorkAxis
    If oWorkAxis.IsCoordinateSystemElement = False Then
    oWorkAxis.Name = "As_Stijl" & i
    i=i+1
Next
JhoelForshav
@mat_hijs
try this 🙂
Just select all workaxes you want to rename and then run the rule.
oDoc = ThisApplication.ActiveDocument
i = 1
Dim oName As String = InputBox("Work axis name:", "Rename workaxes", "As_Stijl_")
For Each oWorkAxis In oDoc.SelectSet
	If TypeOf (oWorkAxis) Is WorkAxis
			Try
				oWorkAxis.Name = oName & i
			Catch
				Dim temp As Integer = i
				While True
					Try
						oWorkAxis.Name = oName & temp
						Exit While
					Catch
						temp += 1
					End Try
				End While
			End Try
			i = i + 1
Next
mat_hijs
Works like a charm! I changed the code a little bit so I get 2 inputboxes, one for a prefix and one for a suffix, and it's gonna save me a good amount of time copying, pasting and editing the names. Thanks!
