VBA Code for exporting SAT files - Help needed from someone with VBA knowledge
不适用
2,842 次查看
24 条回复
1 条消息(共 25 条)
不适用
We currently use a simple VBA macro to generate a DXF of a drawing to a specific folder by clicking on a button. We need the same function for creating a SAT file from an IPT (sheet metal part) and I am struggling to make this work. I know it is probably possible with Ilogic but would prefer to just add have this as the same function we have on the DXF.
This would export the IPT as a 3D model (not the flat pattern) to a specified folder and keep the original filename but as *.SAT
The code we use for the DXF export is below. If any VBA experts out there could help with some code for SAT files it would be appreciated.
Fred
Sub EXPORT()
Dim invApp As Inventor.Application
Set invApp = ThisApplication
invApp.SilentOperation = True
Dim idwDoc As Inventor.DrawingDocument
Set idwDoc = invApp.ActiveDocument
Dim dxfFile As String
dxfFile = idwDoc.FullFileName
dxfFile = "\\HKEURVAULT\Inventor Resources\DXF_FOR_LAYOUTS\" & idwDoc.DisplayName
Mid(dxfFile, Len(dxfFile) - 3) = ".dxf"
With invApp.CommandManager
Call .PostPrivateEvent(kFileNameEvent, dxfFile)
Call .StartCommand(kFileSaveCopyAsCommand)
End With
Set idwDoc = Nothing
invApp.SilentOperation = False
Set invApp = Nothing
End Sub
0 个赞
已接受的解答 (1)
2,843 次查看
24 条回复
回复 (24)
2 条消息(共 25 条)
bradeneuropeArthur
Module CreateSatFile
    Private m_invApp As Inventor.Application
    Public Sub ExportToSat()
        set m_invApp = thisapplication
        Dim oSATTrans As TranslatorAddIn
        set oSATTrans = m_invApp.ApplicationAddIns.ItemById("{89162634-02B6-11D5-8E80-0010B541CD80}")
        If oSATTrans Is Nothing Then
                        Exit Sub
        End If
        Dim oContext As TranslationContext
        set oContext = m_invApp.TransientObjects.CreateTranslationContext
        Dim oOptions As NameValueMap
        set oOptions = m_invApp.TransientObjects.CreateNameValueMap
        If oSATTrans.HasSaveCopyAsOptions(m_invApp.ActiveDocument, oContext, oOptions) Then
            oOptions.Value("ExportUnits") = 5
            oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
            Dim oData As DataMedium
            set oData = m_invApp.TransientObjects.CreateDataMedium
            oData.FileName = "C:\test\TEST.sat"
            Call oSATTrans.SaveCopyAs(m_invApp.ActiveDocument, oContext, oOptions, oData)
        End If
    End Sub
End Module
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
3 条消息(共 25 条)
不适用
Thanks for the code....
How do I set a default network folder and keep the same filename so everytime we save a SAT it goes to a network folder as the existing filename but as a SAT file?
0 个赞
4 条消息(共 25 条)
bradeneuropeArthur
What is your network drive called?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
0 个赞
5 条消息(共 25 条)
不适用
\\hkeurvault\
0 个赞
6 条消息(共 25 条)
bradeneuropeArthur
and your project drive:
like c or d
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
0 个赞
7 条消息(共 25 条)
bradeneuropeArthur
Than use this:
new programmed for network drive: c:\" >>>> to  >>>>"\\hkeurvault\
        Set m_invApp = ThisApplication
        Set oSATTrans = m_invApp.ApplicationAddIns.ItemById("{89162634-02B6-11D5-8E80-0010B541CD80}")
        Exit Sub
        End If
        Set oContext = m_invApp.TransientObjects.CreateTranslationContext
        Set oOptions = m_invApp.TransientObjects.CreateNameValueMap
            Set oData = m_invApp.TransientObjects.CreateDataMedium
            'oData.FileName = "C:\test\TEST.sat"
            Dim oSatFileName As String
            oSatFileName = Replace(m_invApp.ActiveDocument.FullFileName, ".ipt", ".sat") ' ipt to sat
            oSatFileName = Replace(m_invApp.ActiveDocument.FullFileName, "c:\", "\\hkeurvault\") ' c:\ to \\hkeurvault\
            oData.FileName = oSatFileName
        End If
Hope this will help you!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
0 个赞
8 条消息(共 25 条)
不适用
All the drives are networked and we don't use a mapped drive letter and use the full syntax (see attached)
0 个赞
9 条消息(共 25 条)
bradeneuropeArthur
than use the last posted code...
Autodesk Software: Inventor Professional 2018 | Vault Professional 2018 | Autocad Mechanical 2018
Programming Skills: Vba | Vb.net (Add ins Vault / Inventor, Applications) | I-logic
Dimension Component! | Partlist Export! | Derive I-properties! | Vault Prompts Via API! | Vault Handbook/Manual!
Drawing Toggle Sheets! | Vault Defer Update!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
0 个赞
10 条消息(共 25 条)
不适用
Getting there....
Now getting an error (see attached)
0 个赞
11 条消息(共 25 条)
bradeneuropeArthur
Are you using inventor 2015?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
0 个赞
12 条消息(共 25 条)
bradeneuropeArthur
this will do the trick:
        Exit Sub
        End If
            oSatFileName = Replace(m_invApp.ActiveDocument.FullFileName, "C:\", "\\hkeurvault\") ' c:\ to \\hkeurvault\
            MsgBox oSatFileName
        End If
    End Sub
the drive c: was written to lower and must be upper C:
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
0 个赞
13 条消息(共 25 条)
不适用
It is now trying to create an odd folder string but maybe I didn't explain the current structure correctly....
We are using Vault and the local path for our files are C:\VAULT\DESIGNS\ and then we separate the folders further by customer and part number etc. The SAT files we need are for our brake press and need to be on the network server in a flat folder structure her \\hkeurvault\SAT_FILES\
It seems like the code is creating a mixture of the network path and the local path? I attached a couple of screenshots.
0 个赞
14 条消息(共 25 条)
bradeneuropeArthur
So:
The files are located always in for example: C:\VAULT\DESIGNS\Customer001\Brake.ipt
and must be exported always to:  \\hkeurvault\SAT_FILES\Brake.sat
Correct?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
0 个赞
15 条消息(共 25 条)
bradeneuropeArthur
Then this should work:
        Exit Sub
        End If
            On Error Resume Next
            MkDir ("\\hkeurvault\SAT_FILES\")
            Err.Clear
            oData.FileName = "\\hkeurvault\SAT_FILES\" & oSatFileName
        End If
    End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
0 个赞
16 条消息(共 25 条)
不适用
HI,
Yes that is correct but obviously the IPT folder varies every time depending on which files we are exporting to the network.
Andy
0 个赞
17 条消息(共 25 条)
bradeneuropeArthur
please give me two examples of the export folder depending of the file exported.
and please give me the feedback I need to have about what is defining the folder names...
see the new code posted too...
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
0 个赞
18 条消息(共 25 条)
不适用
Hi
Please see screen shots...
Capture6 = current error with new code
Capture7 = IPT typical folder
Capture8 = Network folder (SAT file is there from a manual savecopyas test)
0 个赞
19 条消息(共 25 条)
不适用
Yes still on Inventor 2015 until the end of the year
0 个赞
20 条消息(共 25 条)
不适用
The export folder will always be the same \\HKEURVAULT\SAT_FILES
All of the exported SAT files should be in the same folder with no additional sub folders
Hope it is clear
0 个赞
