Run Rules in parts from an assembly
donaldleigh
donaldleigh
Evening all.
Inventor 2014.
We have a rule that is run from the top level assembly that copies some Iproperties to every part and Sub assembly. This rule is called "Project Details"
Inside each part and Sub assembly we have another rule that generates our part number called "Drawing Part Number Generator" this rule is set to trigger when a iProperty changes. This rule has a if statement that determines if its a part, Sheet Metal or assembly to create different types of part numbers
Everything works fine except when I run "Project Details" in the top level assembly the "Drawing Part Number Generator"  rule in each part/Sub assembly is not triggered for each type. example of this would be if I put a message box in the Sheet Metal part of the code this message box will not appear when the "Project Details"in the top level assembly.
I think it has to do with the
Dim doc As Document = ThisDoc.Document
oDoc = ThisApplication.ActiveDocument
 part in the "Drawing Part Number Generator"  rule. Is there a way to fix this.
I hope I have explained this well enough.
Attached are the rules.
Donald
bradeneuropeArthur
could you show us the complete code.
Seems that you:
  1. first set Dim doc As Document = ThisDoc.Document
  2. then oDoc = ThisApplication.ActiveDocument
Why twice???
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
donaldleigh
I thought I attached them.
Here they are
Sergio.D.Suárez
Hi, on the one hand it seems to me that you should only place the reference to the document as thisdoc.document as I show below
iLogicVb.RunExternalRule("iProperties")
ProNo = iProperties.Value("Custom", "Project Number")
LinNo = iProperties.Value("Custom", "Line Number")
JobNo = ProNo & "-" & LinNo
SeqNo = iProperties.Value("Custom", "Seq Number")
PRTNo = iProperties.Value("Project", "Part Number")
'Set Job Number iProperty
If iProperties.Value("Custom", "Job Number") <> JobNo Then
	iProperties.Value("Custom", "Job Number") = JobNo
	iLogicVb.UpdateWhenDone = True
'Set Drawing Number iProperty
If SeqNo = "" Then
	DRGNo = ""
Else
	DRGNo = ProNo & "-" & LinNo & "-DRG-" & SeqNo
If doc.DocumentType = Inventor.DocumentTypeEnum.kDrawingDocumentObject  Then 'Drawing File
	Return
Else If doc.DocumentType = Inventor.DocumentTypeEnum.kPartDocumentObject  Then 'Part or Sheet Metal File
	If ThisApplication.ActiveDocument.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" = True Then 'Sheet Metal File
		MessageBox.Show("Sheet Metal", "Title")
		DXFSeqNo = iProperties.Value("Custom", "DXF Seq Number")
		DXFNo = ProNo & "-" & LinNo & "-DXF-" & DXFSeqNo
		AltDXFNo = iProperties.Value("Project", "Stock Number")
		If DXFSeqNo = "" Then
			'MessageBox.Show("Please Enter DXF Number", "Title")
			DXFNo = ""
			PRTNo = ""
			AltDXFNo = ""
		Else
			PRTNo = DXFNo
			AltDXFNo = DXFNo
		If iProperties.Value("Custom", "Material Part Number") <> DXFNo Then
			iProperties.Value("Custom", "Material Part Number") = DXFNo
		If iProperties.Value("Project", "Stock Number") <> AltDXFNo Then
			iProperties.Value("Project", "Stock Number") = AltDXFNo
	Else 'Part File
		MatNo = iProperties.Value("Custom", "Material Part Number")
		MatNoLength = Len(MatNo)
		If MatNoLength = 2 Then
			PRTNo = ProNo & "-" & LinNo & "-PRT-" & MatNo
		Else
			PRTNo = MatNo
'		Try
'			LengthPar = Parameter.Param("Length")
'			Call ThisDoc.Document.ComponentDefinition.BOMQuantity.SetBaseQuantity(BOMQuantityTypeEnum.kParameterBOMQuantity, LengthPar)
'		Catch
'			Call ThisDoc.Document.ComponentDefinition.BOMQuantity.SetBaseQuantity(BOMQuantityTypeEnum.kEachBOMQuantity)
'		End Try
Else If doc.DocumentType = Inventor.DocumentTypeEnum.kAssemblyDocumentObject  Then 'Assembly File
	PRTNo = DRGNo
'Dim baseUnit As String
'BaseUnit = doc.ComponentDefinition.BOMQuantity.BaseUnits
'If BaseUnit = ""
'	BaseUnitW = "Each"
'Else
'	BaseUnitW = BaseUnit
'End If
'Set Part Number iProperty
If iProperties.Value("Project", "Part Number") <> PRTNo Then
	iProperties.Value("Project", "Part Number") = PRTNo
'Set Alt Part Number iProperty
If iProperties.Value("Custom", "Drawing Number") <> DRGNo Then
	iProperties.Value("Custom", "Drawing Number") = DRGNo
''Set base Unit iProperty
'If iProperties.Value("Custom", "Base Unit") <> BaseUnitW Then
'	iProperties.Value("Custom", "Base Unit") = BaseUnitW
'	iLogicVb.UpdateWhenDone = True
'End If
 When executing the assembly rule, keep in mind that your rule for each part file requests that an external rule be triggered. Be careful with the external rule that asks to be activated, this rule does have reference to the active document "ThisApplication.ActiveDocument" Work on the active assembly, not on the part file you need.
One possibility would be to integrate the external rule within the rule of your part, perhaps diagramming it as subroutines, then you will forget the document reference
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
chandra.shekar.g
Autodesk Support
Autodesk Support
@donaldleigh,
The object reference ThisDoc.Document may slightly differ from ThisApplication.ActiveDocument in the iLogic environment - so it may refer a different document (e.g. an IPT part).  "ThisDoc" refers to the Autodesk Inventor document in which the rule is written. It is often the active document, but it can also be a part within an assembly. Wherever the rule is stored, ThisDoc gives you access to that document
While the object "ActiveDocument" is the currently active document in terms of the Inventor application - it is not necessarily the same document as the document containing the running ilogic rule. For consistency of proper context in your iLogic code always prefer the reference ThisDoc.Document.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
