SelectMultiple fail
SelectMultiple fail
sebastien.forman
SelectMultiple fail
sebastien.forman
Hello all,
I try to make a script who find and select in panel, all part who don't have body.
I have find this code, but last line "selectmultiple" doesn't work.
Someone can tell me why please?
Thank you very much
Public Sub selectAllNoBody()
Dim ocPartDocs As ObjectCollection
Set ocPartDocs = ThisApplication.TransientObjects.CreateObjectCollection
For Each obj In ThisApplication.ActiveDocument.AllReferencedDocuments
   If TypeOf obj Is PartDocument Then
        Dim oPartdoc As PartDocument
        Set oPartdoc = obj
        If oPartdoc.ComponentDefinition.MassProperties.Volume = 0 Then
              ocPartDocs.Add oPartdoc
              Debug.Print oPartdoc.FullDocumentName
              'ThisApplication.ActiveDocument.SelectSet.Select oPartdoc
Next
Call ThisApplication.ActiveDocument.SelectSet.SelectMultiple(ocPartDocs)
End Sub
AlexFielder
On reading this page, I would assume the same applies for SelectMultiple:
2019-03-12 10_56_04-SelectSet.Select Method _ Search _ Autodesk Knowledge Network.png
Option Explicit
If Not TypeOf ThisApplication.ActiveDocument Is AssemblyDocument Then Exit Sub
Dim assyDoc As AssemblyDocument
Set assyDoc = ThisApplication.ActiveDocument
Dim obj As Object
        Set oPartdoc = obj
Next
Dim ocPartOccurrences As ObjectCollection
Set ocPartOccurrences = ThisApplication.TransientObjects.CreateObjectCollection
Dim AssyDef As AssemblyComponentDefinition
Set AssyDef = assyDoc.ComponentDefinition
Dim partOcc As ComponentOccurrence
For i = 1 To ocPartDocs.Count
    For Each partOcc In AssyDef.Occurrences
        If partOcc.Definition.Document = ocPartDocs.Item(i) Then
            ocPartOccurrences.Add partOcc
    Next
Next i
Call assyDoc.SelectSet.SelectMultiple(ocPartOccurrences)
End Sub
There may be a more efficient approach than the above, but the selection method works at least.
I have an assembly (Inventor 2019.3 format) with several occurrences that according to the code ^ have zero volume, which is incorrect as the do have volume values.
sebastien.forman
Hello Alex,
Thank you for your help, that give me the good way for my script,
Here is my last code with your corrections:
Dim adActiveDoc As AssemblyDocument
Set adActiveDoc = ThisApplication.ActiveDocument
Dim obj As Object
For Each obj In adActiveDoc.ComponentDefinition.Occurrences
   If TypeOf obj Is ComponentOccurrence Then
        Dim oPartdoc As ComponentOccurrence
        Set oPartdoc = obj
        If oPartdoc.MassProperties.Volume = 0 Then
              Debug.Print oPartdoc.name
Next
Call adActiveDoc.SelectSet.SelectMultiple(ocPartDocs)
End Sub
Have a nice day
